zabbix-agent2 on CentOS 7 ipv4 problem
  • anmg
    • Sep 2021
    • 14
    Installed zabbix-agent2 on CentOS 7 and get in stuck with:
    it does not listen ipv4, the only ipv6
    ListenIP=0.0.0.0
    netstat -tulpn | grep zabbix
    tcp6 0 0 :::10050 :::* LISTEN 11369/zabbix_agent2
    error from log:
    cannot parse "ListenIP" parameter: value of ListenIP not present on the host: "0.0.0.0"
  • tim.mooney
    • Dec 2012
    • 1436
    Does the behavior change if you comment out the "ListenIP" entry from the agent config and restart the agent2?
    Does your /etc/hosts have both IPv4 and IPv6 entries for 'localhost'?
    • anmg
      • Sep 2021
      • 14
      nothing changed
      yes
      usual zabbix-agent works
      • Glukas
        • Nov 2021
        • 17
        Normally you doesn't need ListenIP directive, especially when you leave it as 0.0.0.0 - that is the default value.
        Can you disable IPv6 on the host or you need it?
        Even if you need it, you can try to disable just to test.
        • prok_iv
          • May 2024
          Hello, I faced with this moment with agent2 on Debian.... anmg , I will be very appreciate for sharing how you fixed this issue. It looks like very rary case after searching information.
          • fblank
            • Dec 2023
            Any solution to the issue of zabbix-agent2 not listening on IPV4?
            I have the same issue as described above. IPV6 transport gets established when starting the agent2 but no IPV4 listener. I have an Oracle Linux 9 installation with docker compose based zabbix-server (v7.2.1) and another Oracle Linux 9 server with the zabbix-agent2 (v7.2.2) installed from the zabbix repo's (sudo yum install zabbix-agent2)
            • fblank
              • Dec 2023
              Solved!
              turned out to be very simple: The ListenIP in the zabbix-agent2.conf file needs to be filled in with an IPV4 format (contrary to the regular zabbix agent, IPV6 seems to be the default. with the agent2)
