Zabbix server is running = no in the dashboard
  • manu_leo
    • Oct 2015
    Hi Experts, I am on the Zabbix Dashboard and I see Zabbix server is running = no.
    My zabbix.conf.php file looks like
    <?php
    // Zabbix GUI configuration file.
    global $DB;
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '0';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER'] = 'zabbix';
    $DB['PASSWORD'] = 'zabbix.123';
    // Schema name. Used for IBM DB2 and PostgreSQL.
    $DB['SCHEMA'] = '';
    $ZBX_SERVER = 'localhost';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = '192.168.101.216';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    Also under the zabbix-server logs, I see the lot of below message :-
    8866:20151018:092529.689 cannot send list of active checks to [127.0.0.1]: host [abc.xyz.com] not found
    8867:20151018:092729.712 cannot send list of active checks to [127.0.0.1]: host [abc.xyz.com] not found
    I tried to fix this by making an entry under /etc/hosts as below but no go.
    127.0.0.1 localhost abc.xyz.com
    Please suggest and thanks in advance.
  • Ajit
    • Oct 2015
    In zabbix_agentd.conf, you checked that the field ServerActive= is the IP or NS of your Zabbix server?
