MariaDB High CPU and RAM usage issue
  • rhagxxt
    • Oct 2021
    Hello Fellows,
    We have a zabbix server that is experiencing very high CPU consumption due to the mariadb service. This server (an AWS instance) was recently installed and it´s database was migrated from a previous version, as follows:
    Previous setup – CENTOS 7 + Zabbix Server 5.0.15 + MariaDB dist 5.5.60 + PHP 7.2.34
    New setup – CENTOS 8 + Zabbix Server 5.4 + MariaDB dist 10.5 + PHP 7.3
    Once installed and migrated, the new server showing constant high CPU usage, even causing the server to crash. We than increased the server´s RAM as a workaround and increased the innodb_buffer_pool_size.
    The presente hardware setup is: 2 cpu, 8GB RAM and 60GB disc
    The Zabbix Server has around 69 active hosts, 4813 active items and 147nvps.
    So far it is holding, but we still see CPU peaking frequently 80%-100% due to mariadb activity.
    We made some more fine tuning adjustments to the mariadb configuration in na attempt to increase it´s performance, but it seemed to have had little effect. These adjustments are as follows:
    [mysqld]
    datadir=/var/lib/mysql
    socket=/var/lib/mysql/mysql.sock
    max_connections = 400
    max_allowed_packet=1024M
    thread_pool_idle_timeout=7200
    wait_timeout=120
    interactive_timeout=300
    innodb_buffer_pool_instances=2
    innodb_buffer_pool_size=4831838208
    innodb_file_per_table
    innodb_log_file_size=64M
    join_buffer_size=256k
    read_buffer_size=256k
    read_rnd_buffer_size=256k
    table_cache=256
    tmp_table_size=256M
    max_heap_table_size=256M
    query_cache_size=1M
    thread_cache_size=300
    [mariadb]
    log_error=/var/log/mariadb/error.log
    #log_queries_not_using_indexes=/var/log/mariadb/not_using_indexes.log
    slow_query_log=ON
    slow_query_log_file=/var/log/mariadb/mariadb-slow.log
    Also, we activated the slow query log and are seeing a recurrent query that takes 10-15 seconds to complete. Follows the query below:
    # User@Host: zabbix[zabbix] @ localhost []
    # Thread_id: 858953 Schema: zabbix QC_hit: No
    # Query_time: 22.167967 Lock_time: 0.000246 Rows_sent: 25 Rows_examined: 4003131
    # Rows_affected: 0 Bytes_sent: 3134
    SET timestamp=1635358056;
    SELECT a.alertid,a.clock,a.sendto,a.subject,a.message,a.s tatus,a.retries,a.error,a.userid,a.actionid,a.medi atypeid,a.alerttype FROM alerts a WHERE EXISTS (SELECT NULL FROM events e,functions f,items i,hosts_groups hgg JOIN rights r ON r.id=hgg.groupid AND r.groupid=14 WHERE a.eventid=e.eventid AND e.objectid=f.triggerid AND f.itemid=i.itemid AND i.hostid=hgg.hostid GROUP BY f.triggerid HAVING MIN(r.permission)>0 AND MAX(r.permission)>='2') AND EXISTS (SELECT NULL FROM actions aa WHERE a.actionid=aa.actionid AND aa.eventsource='0') AND (a.userid IS NULL OR EXISTS (SELECT NULL FROM users_groups ug WHERE ug.userid=a.userid AND ug.usrgrpid=14)) ORDER BY a.clock DESC LIMIT 25;
    Considering the scenario described above, could anyone kindly confirm:
    - Is this query is running as expected? Does it have any influence on the problem reported?
    - Is there anymore fine tuning that can be done to mariadb in order to optimize it´s CPU performance? Is there anything inaccurately configured?
    Any help will be very appreciated!
    Thanks in advance.
    Best regards!
  • jukka413
    • Oct 2021
    Hello! Are you solve this problem?
    • rhagxxt
      rhagxxt commented
      We had to create a script to restart the MariaDB server every few days, thus freeing up RAM. This was a hack but it's working.
  • tim.mooney
    • Dec 2012
    • 1436
    Originally posted by rhagxxt
    [FONT=Calibri]
    Thanks for including the detail you did in your post.
    You've indicated your Zabbix server and your (new) MariaDB 10.5 instance are on the same server, and that server is configured with 8 GiB of RAM. You've given a little over half of the RAM in the system to MariaDB's InnoDB buffer pool. In a shared scenario like yours, that's about how I would have divided things up too. Ultimately, I think trying 12 GiB or 16 GiB and then upping the innodb_buffer_pool_size so that it's still about half of the system RAM is what I would try next.
    One note: innodb_buffer_pool_instances is deprecated and was basically removed at 10.5. Older documentation for MariaDB from the 10.0 through 10.3 days that talks about performance benefits for splitting the buffer pool into multiple instances no longer applies at 10.5 and later, so you can remove the ..._instances setting and just run one big buffer pool. See: https://mariadb.com/kb/en/innodb-sys...pool_instances
    • jukka413
      • Oct 2021
      We found who makes this slow queries. It's dashboard in zabbix where show action log. If you delete this dashboard it's free temp space on disk.
      CPU was high from trigger "Problem Machines Exist" from "Temlate App Horizon". This triger for item key like "vfs.file.contents" - take info from json file.
