Can not correctly configure trigger to fire only in specific time
  • link0876543
    • Oct 2015
    I want to configure this trigger to fire only on specific time. When I use .time trigger function zabbix report `Incorrect trigger expression`.
    Check Example 10
    The trigger is used to report when 192.168.1.5 becomes unavailable.
    HTML Code:
    {host1.mydomain.com:fping[192.168.1.5].nodata(1m)}=1&{host1.mydomain.com:fping[192.168.1.5].nodata(1m).time(0)}>000000&{host1.mydomain.com:fping[192.168.1.5].nodata(1m).time(0)}<060000
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome to Zabbix forums!
    There is a problem in the expression part where functions are used. Don't use two functions in a row like this: .nodata(1m).time(0)
    Try the following expression:
    {host1.mydomain.com:fping[192.168.1.5].nodata(1m)}=1&{host1.mydomain.com:fping[192.168.1.5].time(0)}>000000&{host1.mydomain.com:fping[192.168.1.5].time(0)}<060000
    Hope this helps!
    Best Regards,
    Ingus
    • link0876543
      • Oct 2015
      When I enter this code I receive error from Zabbix:
      Incorrect trigger expression. Check expression part starting from "1&{host1.mydomain.com:fping[192.168.1.5].time(0)}>000000&{host1.mydomain.com:fping[192.168.1.5].time(0)}<060000".
      • ingus.vilnis
        • Mar 2014
        • 908
        What version of Zabbix are you using?
        If 2.4.x then try the following:
        {host1.mydomain.com:fping[192.168.1.5].nodata(1m)}=1 and {host1.mydomain.com:fping[192.168.1.5].time()}>000000 and {host1.mydomain.com:fping[192.168.1.5].time()}<060000
        Expression syntax was changed a bit there.
        Best Regards,
        Ingus
        • link0876543
          • Oct 2015
          That worked.
          So what was the cause of the problem? Was it new sytax of triggers in new version of Zabbix?
          • ingus.vilnis
            • Mar 2014
            • 908
            Seems you are using 2.4 then but was referring to documentation of 2.2.
            The problem in your case was that you were using trigger expressions with logical AND "&" but starting from 2.4. you have to use "and" for this.
            Best Regards,
            Ingus
