Dashboard widget Trigger Overview vertical label
  • cokomoko
    • Nov 2021
    Hello!
    First of all I must say, how much I love Zabbix, It's the best monitoring software !
    I've been using Zabbix for years now and I've been upgrading my Zabbix server every major release, until now.
    I've decided to setup my new server from scratch and install the lates Zabbix server. I've migrated everything and all works really great, execpt for one small cosmetic problem.
    I can't make the trigger overview label position vertically.
    Has anyone had similar problem? Can anyone give me some guidance?Any help will do.
    zabbix_server (Zabbix) 5.4.7 - new server -normal text, can't make it vertical
    zabbix_server (Zabbix) 4.0.26 - old server - Vertical label, it's show as it should be.
    Thank you all !
  • cokomoko
    • Nov 2021
    Any tips or pointers would be great !
    • Hamardaban
      • May 2019
      • 2714
      I have the same problems. It started "a long time ago" - with version 5.4. If you have a desire, post this problem on https://support.zabbix.com/projects/ZBX/
