Agent won't start.
  • Wido
    • Mar 2006
    • 23
    Agent won't start.
    I have made my own Zabbix Agent packages voor Debian and Ubuntu. They work great, but on one of my servers, the Zabbix agent won't start.
    When i do a strace, i get:
    execve("/usr/local/bin/zabbix_agentd", ["/usr/local/bin/zabbix_agentd"], [/* 15 vars */]) = 0
    uname({sys="Linux", node="reseller08.pcextreme.nl", ...}) = 0
    brk(0)                                  = 0x80b2000
    old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x5556c000
    access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
    open("/etc/ld.so.preload", O_RDONLY)    = -1 ENOENT (No such file or directory)
    open("/etc/ld.so.cache", O_RDONLY)      = 3
    fstat64(3, {st_mode=S_IFREG|0644, st_size=16458, ...}) = 0
    old_mmap(NULL, 16458, PROT_READ, MAP_PRIVATE, 3, 0) = 0x5556d000
    close(3)                                = 0
    open("/lib/tls/libresolv.so.2", O_RDONLY) = 3
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220)\0"..., 512) = 512
    fstat64(3, {st_mode=S_IFREG|0644, st_size=64924, ...}) = 0
    old_mmap(NULL, 73640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x55572000
    old_mmap(0x55581000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x55581000
    old_mmap(0x55582000, 8104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x55582000
    close(3)                                = 0
    open("/lib/tls/libnsl.so.1", O_RDONLY)  = 3
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 <\0\000"..., 512) = 512
    fstat64(3, {st_mode=S_IFREG|0644, st_size=73304, ...}) = 0
    old_mmap(NULL, 80544, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x55584000
    old_mmap(0x55595000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x55595000
    old_mmap(0x55596000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x55596000
    close(3)                                = 0
    open("/lib/tls/libc.so.6", O_RDONLY)    = 3
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`Z\1\000"..., 512) = 512
    fstat64(3, {st_mode=S_IFREG|0755, st_size=1254660, ...}) = 0
    old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x55598000
    old_mmap(NULL, 1264972, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x55599000
    old_mmap(0x556c3000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x129000) = 0x556c3000
    old_mmap(0x556cc000, 7500, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x556cc000
    close(3)                                = 0
    set_thread_area({entry_number:-1 -> 12, base_addr:0x55598940, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
    munmap(0x5556d000, 16458)               = 0
    brk(0)                                  = 0x80b2000
    brk(0x80d3000)                          = 0x80d3000
    brk(0)                                  = 0x80d3000
    open("/etc/zabbix/zabbix_agentd.conf", O_RDONLY) = 3
    fstat64(3, {st_mode=S_IFREG|0644, st_size=121, ...}) = 0
    mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x5556d000
    read(3, "Server=217.115.199.215\nHostname="..., 4096) = 121
    read(3, "", 4096)                       = 0
    open("/etc/zabbix/zabbix_agentd.conf", O_RDONLY) = 4
    fstat64(4, {st_mode=S_IFREG|0644, st_size=121, ...}) = 0
    mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x5556e000
    read(4, "Server=217.115.199.215\nHostname="..., 4096) = 121
    read(4, "", 4096)                       = 0
    getuid32()                              = 0
    socket(PF_FILE, SOCK_STREAM, 0)         = 5
    connect(5, {sa_family=AF_FILE, path="/var/run/.nscd_socket"}, 110) = -1 ENOENT (No such file or directory)
    close(5)                                = 0
    open("/etc/nsswitch.conf", O_RDONLY)    = 5
    fstat64(5, {st_mode=S_IFREG|0644, st_size=465, ...}) = 0
    mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x5556f000
    read(5, "# /etc/nsswitch.conf\n#\n# Example"..., 4096) = 465
    read(5, "", 4096)                       = 0
    close(5)                                = 0
    munmap(0x5556f000, 4096)                = 0
    open("/etc/ld.so.cache", O_RDONLY)      = 5
    fstat64(5, {st_mode=S_IFREG|0644, st_size=16458, ...}) = 0
    old_mmap(NULL, 16458, PROT_READ, MAP_PRIVATE, 5, 0) = 0x556ce000
    close(5)                                = 0
    open("/lib/tls/libnss_compat.so.2", O_RDONLY) = 5
    read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\22\0"..., 512) = 512
    fstat64(5, {st_mode=S_IFREG|0644, st_size=28616, ...}) = 0
    old_mmap(NULL, 31628, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x556d3000
    old_mmap(0x556da000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x6000) = 0x556da000
    close(5)                                = 0
    munmap(0x556ce000, 16458)               = 0
    close(5)                                = 0
    open("/lib/tls/libnss_nis.so.2", O_RDONLY) = 5
    read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\34\0"..., 512) = 512
    fstat64(5, {st_mode=S_IFREG|0644, st_size=33440, ...}) = 0
    old_mmap(NULL, 36620, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x556db000
    old_mmap(0x556e3000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x7000) = 0x556e3000
    close(5)                                = 0
    open("/lib/tls/libnss_files.so.2", O_RDONLY) = 5
    read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\35"..., 512) = 512
    fstat64(5, {st_mode=S_IFREG|0644, st_size=34748, ...}) = 0
    old_mmap(NULL, 38044, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x556e4000
    old_mmap(0x556ed000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x8000) = 0x556ed000
    close(5)                                = 0
    open("/etc/passwd", O_RDONLY)           = 5
    fcntl64(5, F_GETFD)                     = 0
    fcntl64(5, F_SETFD, FD_CLOEXEC)         = 0
    _llseek(5, 0, [0], SEEK_CUR)            = 0
    fstat64(5, {st_mode=S_IFREG|0644, st_size=8070, ...}) = 0
    mmap2(NULL, 8070, PROT_READ, MAP_SHARED, 5, 0) = 0x5556f000
    _llseek(5, 8070, [8070], SEEK_SET)      = 0
    munmap(0x5556f000, 8070)                = 0
    close(5)                                = 0
    setgid32(32000)                         = 0
    setuid32(32000)                         = 0
    setresgid32(-1, 32000, -1)              = 0
    setresuid32(-1, 32000, -1)              = 0
    clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x55598988) = 31038
    exit_group(0)
    reseller08:~# /usr/local/bin/zabbix_agentd -v
    ZABBIX Agent (daemon) v1.1.2 (19 July 2006)
    Compilation time:  Sep 18 2006 18:05:58
    reseller08:~#
    The strace looks fine to me, but still, the Zabbix agent won't start.
    My zabbix_agentd.conf looks like:
    Hostname=localhost
    StartAgents=5
    DebugLevel=3
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    Timeout=5
    Any ideas?
  • Wido
    • Mar 2006
    • 23
    Little kick?
    • den_crane
      • Feb 2006
      • 272
      Originally posted by Wido
      ...but on one of my servers, the Zabbix agent won't start.
      uname -a
      may be server has different platform (for example 64bit)
      • Wido
        • Mar 2006
        • 23
        Originally posted by den_crane
        uname -a
        Linux reseller08.pcextreme.nl 2.6.15-27-amd64-k8 #1 SMP PREEMPT Thu Jul 20 15:
        :29 CEST 2006 x86_64 GNU/Linux
        reseller08:~#
        A little side note, it worked before on this server.
        This is a Linux VServer guest (Debian Sarge 32Bits) running on a Ubuntu Dapper (AMD64) system.
        The agent worked, but it justed stopped working after a few weeks.
        The rest of the services runs fine, it is only Zabbix wich is giving me troubles.
        • Wido
          • Mar 2006
          • 23
          Well, i still got this problem.
          Currently i am running 1.1.4 and i have this problem on 6 Debian Sarge servers.
          apt-get update && apt-get upgrade has been done, all the libraries are up to date.
          Some debug information:
          reseller01:~# file /usr/local/bin/zabbix_agentd
          /usr/local/bin/zabbix_agentd: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), for GNU/Linux 2.2.0, dynamically linked (uses shared libs), not stripped
          reseller01:~# uname -a
          Linux reseller01.pcextreme.nl 2.6.8-3-686-smp #1 SMP Thu Sep 7 04:39:15 UTC 2006 i686 GNU/Linux
          reseller01:~#
          reseller08:~# file /usr/local/bin/zabbix_agentd
          reseller08:~# uname -a
          Linux reseller08.pcextreme.nl 2.6.16.29-xen #3 SMP Sun Oct 15 13:15:34 BST 2006 x86_64 GNU/Linux
          reseller08:~#
          On both servers the Zabbix Agent will not start.
          ZABBIX Agent (daemon) v1.1.4 (14 November 2006)
          And again, the output of strace
          reseller01:~# strace zabbix_agentd
          execve("/usr/local/bin/zabbix_agentd", ["zabbix_agentd"], [/* 18 vars */]) = 0
          uname({sys="Linux", node="reseller01.pcextreme.nl", ...}) = 0
          brk(0)                                  = 0x80b2000
          old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
          open("/etc/ld.so.preload", O_RDONLY)    = 3
          fstat64(3, {st_mode=S_IFREG|0644, st_size=16, ...}) = 0
          old_mmap(NULL, 16, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x40018000
          close(3)                                = 0
          open("/lib/snoopy.so", O_RDONLY)        = 3
          read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\10\0"..., 512) = 512
          fstat64(3, {st_mode=S_IFREG|0644, st_size=4616, ...}) = 0
          old_mmap(NULL, 7696, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40019000
          old_mmap(0x4001a000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x4001a000
          close(3)                                = 0
          munmap(0x40018000, 16)                  = 0
          fstat64(3, {st_mode=S_IFREG|0644, st_size=17888, ...}) = 0
          old_mmap(NULL, 17888, PROT_READ, MAP_PRIVATE, 3, 0) = 0x4001b000
          close(3)                                = 0
          old_mmap(NULL, 73640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40020000
          old_mmap(0x4002f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x4002f000
          old_mmap(0x40030000, 8104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40030000
          close(3)                                = 0
          old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40032000
          old_mmap(NULL, 80544, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40033000
          old_mmap(0x40044000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x40044000
          old_mmap(0x40045000, 6816, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40045000
          close(3)                                = 0
          old_mmap(NULL, 1264972, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40047000
          old_mmap(0x40171000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x129000) = 0x40171000
          old_mmap(0x4017a000, 7500, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4017a000
          close(3)                                = 0
          open("/lib/tls/libdl.so.2", O_RDONLY)   = 3
          read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\32"..., 512) = 512
          fstat64(3, {st_mode=S_IFREG|0644, st_size=9872, ...}) = 0
          old_mmap(NULL, 8632, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4017c000
          old_mmap(0x4017e000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0x4017e000
          close(3)                                = 0
          old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4017f000
          set_thread_area({entry_number:-1 -> 6, base_addr:0x4017f080, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
          munmap(0x4001b000, 17888)               = 0
          brk(0)                                  = 0x80b2000
          brk(0)                                  = 0x80d3000
          mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001b000
          mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001c000
          getuid32()                              = 0
          close(5)                                = 0
          mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001d000
          close(5)                                = 0
          munmap(0x4001d000, 4096)                = 0
          fstat64(5, {st_mode=S_IFREG|0644, st_size=17888, ...}) = 0
          old_mmap(NULL, 17888, PROT_READ, MAP_PRIVATE, 5, 0) = 0x40180000
          close(5)                                = 0
          old_mmap(NULL, 31628, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x40185000
          old_mmap(0x4018c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x6000) = 0x4018c000
          close(5)                                = 0
          munmap(0x40180000, 17888)               = 0
          close(5)                                = 0
          old_mmap(NULL, 36620, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x4018d000
          old_mmap(0x40195000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x7000) = 0x40195000
          close(5)                                = 0
          old_mmap(NULL, 38044, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0) = 0x40196000
          old_mmap(0x4019f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0x8000) = 0x4019f000
          close(5)                                = 0
          fstat64(5, {st_mode=S_IFREG|0644, st_size=19350, ...}) = 0
          mmap2(NULL, 19350, PROT_READ, MAP_SHARED, 5, 0) = 0x40180000
          _llseek(5, 19350, [19350], SEEK_SET)    = 0
          munmap(0x40180000, 19350)               = 0
          close(5)                                = 0
          setgid32(32000)                         = 0
          setuid32(32000)                         = 0
          clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x4017f0c8) = 17045
          --- SIGCHLD (Child exited) @ 0 (0) ---
          exit_group(0)                           = ?
          reseller01:~#
          It really starts to annoy me, what is going wrong here?
          • jeff.showers
            • Aug 2006
            • 18
            Can you change your DebugLevel to 4 and see if that gives any more meaningful error data to work with?
            • Wido
              • Mar 2006
              • 23
              Yes, it resolved it.
              I had to remove all the zabbix* files in /tmp, after removing those it worked again.
              Really, why didn't i figure this out earlier?
              • jeff.showers
                • Aug 2006
                • 18
                No worries. Lord knows we all get caught up in a problem and start to overlook some things at some point. =)
