Pollers hanging up
  • leos
    • Nov 2021
    Pollers hanging up
    Hello everyone.
    I have a little issue. The data pollers are getting stuck.
    You can see my attached screenshots. More and more pollers are getting stuck until everything item cannot get any new data. I have to restart zabbix-server to recover the pollers.
    The pollers gets stuck with, for example, "[got 16 values in 5.016000 sec, getting values]". And it never changes the status.
    I think maybe is an item that has some issue. But I don't know which one.
    There are no locks on the mysql DB. CPU and memory are very low usage. I enabled 100 pollers (when 20 of them were enough).
    I tried to increase debug level, but nothing out of normal seems to be happening.
    Zabbix version is 5.4.6, running Ubuntu 20.04.
    Thanks in advance for any help you can give me.
  • leos
    • Nov 2021
    It's been some time since I asked about this.
    Less frequently but it is still happening.
    The only difference from before, that with Zabbix 6.0.4 they add a new poller for ODBC. And that is what's. I can't find which DB query is causing the issue, or why. We do a lot of queries to several and different DB Servers and instances.
    If anyone knows how to debug the poller when I see it's stuck, please let me know.
    Thanks!!
    • Markku
      • Sep 2018
      • 1788
      Just an idea: If the problem can be identified by the duration of the TCP sessions to the monitored databases, you could try capturing all the database connections on Zabbix server using tcpdump, and then using Wireshark statistics (or other similar tools) to find out the database connections that are problematic.
      Disclaimer: It's up to you to find out if you can do that in accordance to your security and other relevant operational policies.
      Markku
      • tim.mooney
        • Dec 2012
        • 1437
        Why? If 20 were enough (possibly more than enough) why increase pollers to 100?
        Keep in mind that the more pollers you run, the more chance there is for contention for certain resources, including database resources.
        With some types of software, you can set certain configuration parameters to values that are "larger than I will ever need" and not have any issues, but Zabbix isn't one of them where that's a good idea.
        In general, you only want to run as many of each subsystem as your environment requires. Since you haven't told us a lot about your environment (for example, what your "new values per second (NVPS)" is, how many hosts you have, how many items you have, etc.), it's impossible to know what the right values are for you environment, but I'm suspicious that 100 pollers (or even 20 pollers) is more than you need (and may be part of the problem).
        Also, typically when your environment is large enough to require you to increase the counts for multiple subsystems, that also means that database tuning is also useful.
        If you provide more information about your environment, it may shed some light on the issue.
          • 5004
          How is the data looking? with gaps? probably not getting all the data all the time...?
          Evetho you said you did it already... but try again... Increase the logging level of one or two pollers and let them run for a while, then look in logs. what are they up to. Which hosts and which items they have been dealing with etc... You should be able to track down those things, which either lock your pollers or cause timeouts etc...
          • leos
            • Nov 2021
            A poller just get stuck. I don't see any noticeable gap. I checked hours later, and the poller still shows the same info, for example: "odbc poller #3 [got 3 values in 0.251546 sec, getting values]"
            One by one, with enough time, I run out of "good" pollers, and then is when the bad things happen, as I don't get any new values at all.
            If I can debug, see what was the last value/query that was trying to get, I could fix it.
            I tried with debug level, but I found nothing.
            • MR_ROSS
              • Jan 2026
              Hello. I would like to refresh this topic.
              We have 20 ODBC pollers running but no data being polled, at all.
              Using htop I can see process name / title not changing: odbc poller #8 [got 34 values in 0.000126 sec, idle 5 sec] (example title). Despite only one poller being hung up like this, there is no odbc data being polled at all.
              Changing log level for odbc pollers via runtime commands seem to have no effect - nothing appears in the .log file, even on maximum debug level (5). Works if I specify any other poller type than odbc, so my command is correct.
              Command used:sudo zabbix_proxy -c /etc/zabbix/zabbix_proxy.conf -R log_level_decrease="odbc poller"
              Enabling profiling for odbc pollers via runtime commands seem to also have no effect - same situation, nothing appears in the .log file. No matter if I enable profiling for profiler, profiler type or PID. Works if I specify any other poller than odbc, so command is correct.
              Command used: sudo zabbix_proxy -c /etc/zabbix/zabbix_proxy.conf -R prof_disable="odbc poller"
              All of the above was done to try debugging in real time, while the situation was happening. There was complete lack of any output or any useful information. It's like pollers just stopped working (despite working).
              Information about what specific pollers do or their last known status (even if stuck) would be immensely useful. Detailed informations even more useful, such as what query was being last executed, on what server or last tcp session status.
              Naturally we have restarted zabbix_proxy and it works... for now.
              Zabbix proxy version: 7.4.6, although we have upgraded it to 7.4.7 and we'll see if it happens again.
              Does anyone have any experience with such situation?
              • Silver_47
                • Oct 2022
                I have three Zabbix installations, one version 5 and two version 7. All three Zabbix installations query the same Oracle databases. On both Zabbix 7 installations, I have intermittent ODBC poilers freezes, while on Zabbix 5 everything works correctly. No debugging steps helped either. The "getting values" message persists until I restart zabbix_proxy.
                ├─ 810817 "/usr/sbin/zabbix_proxy: odbc poller #1 [got 5 values in 0.416012 sec, getting values]"
                ├─ 810818 "/usr/sbin/zabbix_proxy: odbc poller #2 [got 0 values in 0.000023 sec, getting values]"
                ├─ 810820 "/usr/sbin/zabbix_proxy: odbc poller #3 [got 5 values in 3.157194 sec, getting values]"
                ├─ 810821 "/usr/sbin/zabbix_proxy: odbc poller #4 [got 0 values in 0.000033 sec, getting values]"
                • conny.lindqvist@presto.se
                  • Jun 2024
                  I have one poller/proxy in my enviroment and it seems to want to hang/freeze every 2-3 weeks or so. Happened twice since install. Last reboot was 2 weeks ago so I expect it to hang soon.
                  No logs to show for it yet. Running latest version. 7.4.7 with Ubuntu 24.04 as OS.
                  Only way to recover is a forced reboot. It hangs so badly you cant do a normal reboot.
