Zabbix Client Access Denied
  • Prakhar Budholiya
    • Nov 2015
    Hi All,
    I have zabbix installed on my wan ip and I'm able to add clients in that of same Wan Pp network, But when i'm trying to add a zabbix client of different Wan network range, i'm getting -
    " Received empty response from Zabbix Agent at [x.x.x.x]. Assuming that agent dropped connection because of access permission. "
    There is no filtering at any end, and i have cross checked zabbix_agentd.conf file may times and found no errors. I can see ports listening at 10050 on client servers.
  • Prakhar Budholiya
    • Nov 2015
    I have solved the above problem. it was my router's wan ip that was collecting the data from zabbix agent and not the zabbix server's wan ip. so i gave both the ips of my router as well as of zabbix server in zabbix_agentd.conf's Server and ServerActive . and now its working fine. Thanks
