Script with macros as parameters
  • markfree
    • Apr 2019
    • 875
    I'm getting an error when trying to start manually a global script from Zabbix 5.0.
    Script command executed on Zabbix server:
    /usr/lib/zabbix/externalscripts/rde/rde_criar.sh "{HOST.HOST}" "{HOST.IP}" "{HOST.NAME}" "{EVENT.NAME}"​ "{TRIGGER.DESCRIPTION}" "{ITEM.VALUE}" "{EVENT.SEVERITY}" "{EVENT.DATE}" "{EVENT.TIME}" "{EVENT.AGE}" "{EVENT.STATUS}" "{EVENT.ACK.STATUS}"
    ERROR:
    [SCRIPT ERROR MESSAGE]
    Cannot execute script
    /usr/lib/zabbix/externalscripts/rde/rde_criar.sh "esbsa009908jc1" "" "esbsa009908jc1" "{EVENT.NAME}"​ "{TRIGGER.DESCRIPTION}" "{ITEM.VALUE}" "{EVENT.SEVERITY}" "{EVENT.DATE}" "{EVENT.TIME}" "{EVENT.AGE}" "{EVENT.STATUS}" "{EVENT.ACK.STATUS}"
    The error above shows that macros are not properly resolved.
    For Zabbix 5.0 I get this error.
    For Zabbix 5.4 it just works.
    Is there a parameter limit for Zabbix 5.0?
  • markfree
    • Apr 2019
    • 875
    If I change the parameters order, I can see that only Host macros bellow are resolved.
    That suggests me that the script is not receiveing event data.
    In Zabbix 5.0, I'm starting the script at the Dashboard "Problems" widget and "Host" column.
    But in Zabbix 5.4, I can start the script from "Problem - Severity" column.
    • markfree
      • Apr 2019
      • 875
      I think I found what's going on.
      Zabbix 5.0 does not support event macros for global scripts.
      In contrast, Zabbix 5.4 supports manual event action scripts.
      That's a bummer.
