6.0 Pre-Release Repo certificate error
  • jamesonjjameson
    • Nov 2021
    Hi All,
    I'm attempting to install the 6.0 pre-release, when running the apt-update after installing the PKG, I'm seeing :
    Failed to fetch https://repo.zabbix.com/zabbix/5.5/u...source/Sources Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate. Could not handshake: Error in the certificate verification.
    I'm not sure how to let them know about this cert and/or if there's a workaround?
    Thanks for any input
    • 5004
    This error is related to LetsEncrypt's cert expiration https://letsencrypt.org/docs/dst-roo...eptember-2021/
    But to resolve this You should update your own system and get newer root certs.
    • jamesonjjameson
      • Nov 2021
      Hi Appreciate, the input! I did run the update and it resolved the issue.
      Thanks again
