Clean CentOS8 and Ubuntu 20.04 install
Installed net-snmp and can snmpwalk devices just fine
Installed Zabbix agent and edited Server = 10.x.x.x and HostName=ZabbixServerHostName
Restarted services
On Zabbix server, I added a proxy and entered the information with port 10050 for passive
Zabbix server shows it connected and refreshes correctly
However, any device I attempt to monitor with the proxy will not have it's SNMP turn green and stops polling everything.
I've waited several days and still nothing
Agent logs look fine, but sometimes shows this:
33211:20211126:193744.041 zbx_setproctitle() title:'collector [idle 1 sec]'
33212:20211126:193744.126 zbx_setproctitle() title:'listener #1 [processing request]'
33212:20211126:193744.126 zbx_tcp_recv_ext(): received 32 bytes with compression ratio 0.8
33212:20211126:193744.126 Requested [{"request":"proxy data"}]
33212:20211126:193744.126 Sending back [ZBX_NOTSUPPORTED: Invalid item key format.]
33212:20211126:193744.126 zbx_setproctitle() title:'listener #1 [waiting for connection]'
33214:20211126:193744.482 zbx_setproctitle() title:'listener #3 [processing request]'
33214:20211126:193744.482 Requested [system.cpu.load[all,avg5]]
33214:20211126:193744.482 Sending back [0.040000]
33214:20211126:193744.483 zbx_setproctitle() title:'listener #3 [waiting for connection]'
33211:20211126:193745.042 zbx_setproctitle() title:'collector [processing data]'
33211:20211126:193745.042 In update_cpustats()
33211:20211126:193745.042 End of update_cpustats()
I don't think the Invalid item key format is the problem. Can anyone help me find out why the proxy agent does not work with SNMP?
Thank you!
Restarted services
Thank you!
