Graphs and templates
  • Vince2
    • Oct 2006
    • 40
    Hi !
    With Zabbix 1.1.2, I cannot create a graph for a template while it was possible with past versions. I have looked at the CVS and spotted this change :
    Download Zabbix for free. Enterprise-class, distributed monitoring solution for networks & apps. Zabbix is an enterprise-class open source distributed monitoring solution designed to monitor and track performance and availability of network servers, devices and other IT resources. It supports distributed and WEB monitoring, auto-discovery, and more.
    The only effect of this change is to disallow graph creation for templates. I suppose that this change was needed for something else but the comment seems unclear for me.
    How to create a graph for a template ?
  • cadbury
    • Apr 2005
    • 77
    well, I use zabbix 1.1.2 and I created graphs in templates
    just create a normal graph, and when you add an item, select a parameter from a template
    but after that, as the template is not on the list of hosts on graphs config page, you have to display all graphs to see those from templates.
    It would be nice to have the templates in this list, and also to have a special host in this list for graphs that have no items (graphs you just created).
