Zabbix proxy not transmitting data zabbix server
  • zmdpc
    • Oct 2014
    • 484
    After updating the template is connected to a large number hosts queue of items increased to a maximum of about 12 hours, and location in a such a state. What could cause such an effect? There are no errors in the log
    conf proxy
    PHP Code:
    ProxyMode=0
    Server
    =хххх
    HostnameItem=system.hostname
    LogFile
    =/var/log/zabbix/zabbix_proxy.log
    LogFileSize
    =10
    DebugLevel
    =3
    PidFile
    =/var/log/zabbix/zabbix_proxy.pid
    DBName
    =хххх
    DBUser=хххх
    DBPassword=хххх
    DBSocket=/var/run/mysqld/mysqld.sock
    ProxyLocalBuffer
    =2
    ProxyOfflineBuffer
    =12
    ConfigFrequency
    =300
    StartPollers
    =55
    StartPollersUnreachable
    =12
    StartTrappers
    =12
    StartPingers
    =12
    SNMPTrapperFile
    =/var/trapd/zabbix_traps.tmp
    StartSNMPTrapper
    =1
    CacheSize
    =256M
    StartDBSyncers
    =10
    HistoryCacheSize
    =128M
    HistoryTextCacheSize
    =128M
    Timeout
    =3
    FpingLocation
    =/usr/bin/fping
    SSHKeyLocation
    =/home/zabbix/.ssh
    conf server
    HTML Code:
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=10
    DebugLevel=3
    PidFile=/var/log/zabbix/zabbix_server.pid
    DBName=xxxxx
    DBUser=xxxxx
    DBPassword=xxxxxxx
    StartPollers=10
    StartPollersUnreachable=5
    StartTrappers=15
    StartPingers=3
    StartTimers=5
    CacheSize=350M
    StartDBSyncers=10
    HistoryCacheSize=32M
    TrendCacheSize=64M
    HistoryTextCacheSize=64M
    ValueCacheSize=160M
    Timeout=3
    AlertScriptsPath=/usr/local/share/zabbix/alertscripts
    ExternalScripts=/usr/local/share/zabbix/externalscripts
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    SSHKeyLocation=/home/zabbix/.ssh
  • ingus.vilnis
    • Mar 2014
    • 908
    Check internal graphs for Zabbix server and proxies. Maybe data senders are busy on proxies. Maybe configuration syncers are busy on server.
    Also you are not logging slow queries on your systems so it is recommended to use this option. Thus you will see if database performance is bad.
    LogSlowQueries=3000
    Best Regards,
    Ingus
