Proxy connectivity grrrr
  • 999frogs
    • Nov 2021
    Proxy doesn't seem to be requesting data from agents ?
    Server 5.4.4 running in a CentOS VM
    Proxy 5.4.7 in a docker container
    Agents 5.4.X in Ubuntu/CentOS VMs
    Active Proxy
    Server can see proxy (last seen & logfile messages)
    - proxy logs showing "...received configuration data from server at..." messages
    - server logs showing ".. sending configuration data to proxy "zabbix-proxy-container" at ..." messages
    Each logfile repeating these messages every minute (I set it low deliberately)
    Immediately after the first "... received configuration data" in the proxy log, I see " 267:20211214:125543.012 Zabbix agent item "vm.memory.size[available]" on host "********" failed: first network error, wait for 15 seconds
    BUT logged into the container, from the command line:
    zabbix_get -s xxx.xxx.xxx.xxx --tls-connect psk --tls-psk-identity Zabbixpsk --tls-psk-file /var/lib/zabbix/enc/zabbixproxy.psk -k "vm.memory.size[available]"
    works
    Names match exactly
    All hosts have similar issue
    Agent log file has these lines in response to the zabbix_get request
    2021/12/14 13:38:15.530487 received passive check request: 'vm.memory.size[available]' from 'xxx.xxx.xxx.xxx'
    2021/12/14 13:38:15.530557 [1] processing update request (1 requests)
    2021/12/14 13:38:15.530580 [1] adding new request for key: 'vm.memory.size[available]'
    2021/12/14 13:38:15.530588 [1] created direct exporter task for plugin 'Memory' itemid:0 key 'vm.memory.size[available]'
    2021/12/14 13:38:15.530651 executing direct exporter task for key 'vm.memory.size[available]'
    2021/12/14 13:38:15.531067 executed direct exporter task for key 'vm.memory.size[available]'
    2021/12/14 13:38:15.531110 sending passive check response: '30456983552' to 'xxx.xxx.xxx.xxx'
    Thoughts and solution welcomed, am tearing my hair out !
    D
  • 999frogs
    • Nov 2021
    Still struggling here guys, any input welcomed.
    Thanks !
