Fedora OS 34.
#./configure --libdir=/usr/lib64 --enable-server --enable-agent --enable-proxy --enable-java --with-mysql --with-net-snmp --with-libcurl --with-libxml2 --with-ssh2 --with-openipmi --with-unixodbc --with-openssl --enable-ipv6 --enable-agent2 --enable-webservice
--- ok ---
#make install clean
... cut ---
make[3]: Entering directory '/root/zbx/zabbix-5.4.8/src/go'
/usr/bin/mkdir -p '/usr/local/etc'
/usr/bin/install -c -m 644 conf/zabbix_agent2.conf conf/zabbix_web_service.conf '/usr/local/etc'
CGO_CFLAGS="-I/usr/include" CGO_LDFLAGS="-L/usr/lib -Wl,--start-group /root/zbx/zabbix-5.4.8/src/zabbix_agent/logfiles/libzbxlogfiles.a /root/zbx/zabbix-5.4.8/src/libs/zbxcomms/libzbxcomms.a /root/zbx/zabbix-5.4.8/src/libs/zbxcommon/libzbxcommon.a /root/zbx/zabbix-5.4.8/src/libs/zbxcrypto/libzbxcrypto.a /root/zbx/zabbix-5.4.8/src/libs/zbxsys/libzbxsys.a /root/zbx/zabbix-5.4.8/src/libs/zbxnix/libzbxnix.a /root/zbx/zabbix-5.4.8/src/libs/zbxconf/libzbxconf.a /root/zbx/zabbix-5.4.8/src/libs/zbxhttp/libzbxhttp.a /root/zbx/zabbix-5.4.8/src/libs/zbxcompress/libzbxcompress.a /root/zbx/zabbix-5.4.8/src/libs/zbxregexp/libzbxregexp.a /root/zbx/zabbix-5.4.8/src/libs/zbxsysinfo/libzbxagent2sysinfo.a /root/zbx/zabbix-5.4.8/src/libs/zbxsysinfo/common/libcommonsysinfo.a /root/zbx/zabbix-5.4.8/src/libs/zbxsysinfo/simple/libsimplesysinfo.a /root/zbx/zabbix-5.4.8/src/libs/zbxsysinfo/linux/libspechostnamesysinfo.a /root/zbx/zabbix-5.4.8/src/libs/zbxsysinfo/linux/libspecsysinfo.a /root/zbx/zabbix-5.4.8/src/libs/zbxexec/libzbxexec.a /root/zbx/zabbix-5.4.8/src/libs/zbxalgo/libzbxalgo.a /root/zbx/zabbix-5.4.8/src/libs/zbxjson/libzbxjson.a -lm -ldl -lresolv -lxml2 -lpcre -lz -lpthread -lssl -lcrypto -Wl,--end-group" GOBIN=/usr/local/sbin \
go install -ldflags="-X 'zabbix.com/pkg/version.compileDate=`date +"%b %_d %Y"`' -X zabbix.com/pkg/version.compileTime=`date +%H:%M:%S` -X zabbix.com/pkg/version.compileOs=`go env GOOS` -X zabbix.com/pkg/version.compileArch=`go env GOARCH` -X main.confDefault=/usr/local/etc/zabbix_agent2.conf -X main.applicationName=zabbix_agent2" zabbix.com/cmd/zabbix_agent2 zabbix.com/cmd/zabbix_web_service
go: golang.org/x/[email protected]: unrecognized import path "golang.org/x/sys": http/https fetch: Get "http://golang.org/x/sys?go-get=1": dial tcp 216.58.208.209:80: i/o timeout
make[3]: *** [Makefile:625: install-zabbix.com/cmd/zabbix_agent2] Error 1
make[3]: Leaving directory '/root/zbx/zabbix-5.4.8/src/go'
make[2]: *** [Makefile:505: install-am] Error 2
make[2]: Leaving directory '/root/zbx/zabbix-5.4.8/src/go'
make[1]: *** [Makefile:505: install-recursive] Error 1
make[1]: Leaving directory '/root/zbx/zabbix-5.4.8/src'
make: *** [Makefile:542: install-recursive] Error 1
Please help.
--- ok ---
#make install clean
... cut ---
Please help.
