API. Method 'host.create'. Error 'Invalid Request.'
  • stincv
    • Nov 2015
    Hi.
    The script looks like this:
    PHP Code:
    $url = "http://***/zabbix/api_jsonrpc.php";
    function
    send_request($url,$json) {
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
    curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
    curl_setopt($ch, CURLOPT_HTTPHEADER, array('Content-Type: application/json'));
    curl_setopt($ch, CURLOPT_URL,$url);
    curl_setopt($ch, CURLOPT_POST, 1);
    curl_setopt($ch, CURLOPT_POSTFIELDS,$json);
    curl_setopt($ch, CURLOPT_USERPWD, "***:***");
    $result=curl_exec($ch);
    curl_close($ch);
        return
    json_decode($result);
    $json = '{
       "jsonrpc": "2.0",
       "method": "user.login",
       "params": {
          "user": "admin",
          "password": "***"
       "id":1
    $res = send_request($url,$json);
    $auth = $res->result;
    var_dump($auth);
    $json = '{
        "jsonrpc": "2.0",
        "method": "host.create",
        "params": {
            "host": "domain.ru",
            "interfaces": [
                    "type": 1,
                    "main": 1,
                    "useip": 1,
                    "ip": "192.168.0.1",
                    "dns": "domain.ru",
                    "port": "10050"
            "groups": [
                    "groupid": "9"
            "templates": [
                    "templateid": "10130"
        "auth": "'
    .$auth.'",
        "id":1
    var_dump($res);
    The output is:
    PHP Code:
    string(32) "c96ceaf1051c3410a43f73541f8c1c05"
    object(stdClass)#2 (3) {
    ["jsonrpc"]=>
    string(3) "2.0"
    ["error"]=>
    object(stdClass)#3 (3) {
    ["code"]=>
    int(-32600)
    "message"]=>
    string(16) "Invalid Request."
    ["data"]=>
    string(34) "JSON-rpc version is not specified."
    "id"]=>
    NULL
    As can be seen the first authorization request passes but the second request "----" does not pass, although the request was for the documents and errors there may be no.
    Help, why the error?
    I found a solution to the problem itself
    after the last element of the array must not be a comma
    Last edited by stincv; 11-11-2015, 14:37. Reason: I found a solution to the problem itself
