On what OS did you install the Zabbix server? Installing means that everything is in place, but starting the server and starting it at boot may not be automatically set. On Linux the following command might work:
sudo service zabbix-server start
This will start the server, but after a reboot it won't start automatically. That depends on your system.
If you have agents installed, you might want to start this as well:
