LDAP - Connected, but no logon possible even not with local admin
  • channoine
    • Dec 2021
    Hello;
    just had install and run zabbix for some months now.
    I tried to do a LDAP-Connection which worked - so far so good.
    After loggin out and trying to log in again I get the message "Incorrect user name or password or account is temporarily blocked."
    Therefore I disabled the LDAP authentication, and tried to login with local Admin.
    As I got the same message I thought I hab saved the wrong Admin-Password in our password database.
    I resetted the Admin-password like
    update zabbix.users set passwd=md5('zabbix') where alias='Admin';
    But I still can not login.
    Is there a way to fix this?
    Regards
    Channoine
  • channoine
    • Dec 2021
    Hi;
    -> SOLVED
    I have disabled the ServiceAccount on Windows site and then rebooted the system, tried to login again - nothing worked, then activated the LDAP-Sync-Account again.
    Now I am able to login with local accounts again.
    I do not understand - maybe I will find somethin i the log files.
    Regards
    Channoine
