Error fsockopen(): Unable to connect to localhost:10051 after upgrading from 5 to 5.4
  • kevinmorales559
    • Jan 2022
    Sorry for my english, i'm using a translator
    Good afternoon, I have the following problem, running zabbix in a virtual environment (vmware) in Ubuntu 21.10, only in my case I did an update from 5.0 to 5.4 and it throws me the error when entering the dashboard:
Name:	zabbix error.png
    I do a telnet to the local host but I get the following:
    [root@zabbix-server]# telnet localhost 10051
    Trying 127.0.0.1...
    telnet: connect to address 127.0.0.1: Connection refused
    But if I do it to 10050 this comes out:
    [root@zabbix-server]# telnet localhost 10050
    Trying 127.0.0.1...
    Connected to local host.
    Escape character is '^]'.
    Connection closed by foreign host.
    I followed the instructions in the following url:
    After installing the new repository I get the following error:
    *Unable to establish SSL connection.
    I run the following command:
    I continue with the steps below, and the error appears
    This error is because in the zabbix_server.conf file there was no database password, I put the password and restart the zabbix-server service and everything normal, update the database, I enter the dashboard and that's when the error appears from image 1
    **I did the same upgrade procedure on another server ubuntu 20.04 and there were no problems when entering the dashboard**
