segmentation fault zabbix agent rpi zero w
  • toma.luca95
    • Sep 2017
    I'm getting "segmentation fault" tring to run zabbix agent2 or zabbix sender from repo.zabbix.com for bullseye, the one from buster works fine.
    After some test i found out that armv6l has this problem but not armv7l.
    Someone has the same problem?
  • tsl
    • Mar 2016
    Yes, I just updated a Raspberry 1 and the same issue happens...
    • LenR
      • Sep 2009
      • 1011
      Same on a pi zero w. Did you ever get it fixed?
      zabbix-agent/unknown,now 1:6.0.0-1+debian11 armhf [installed]
      • toma.luca95
        • Sep 2017
        There is a bug report https://support.zabbix.com/browse/ZBX-20468
