How to convert ASCII String to other formats
  • pmvw@alaskapublic.org
    • Jul 2020
    After fighting and winning my SNMP battle earlier today, I felt really confident that I would have all the data I needed from my 10 Microwave SNMP devices. They were quick to offer up their SNMP data, after getting their OIDs correct.
    I went for the low hanging fruit first, a simple number?!? This is what was retrieved:
    "20 20 20 32 35 2E 30 30 00"
    OMG.... NOOOoooo. It's ASCII code!! Is there anything built into Zabbix that I can push this through and all the other texts to actually get it converted. Either to store the regular text or to the numbers they need to be?
    (Yes every text is this way... even text is in ASCII code.)
    Thanks.
    Piet
    • 5002
    JS preprocessing ...
      • Jul 2020
      Ok... cyber was indeed correct. JS Preprocessing is the answer. (Thank you!)
      Since I HATE to leave questions unanswered on forums...
      Found a gem of a JS Preprocessing snippits here...
      remove duplicate text values: function uniq(a) { return a.sort().filter(function(item, pos, ary) { return !pos || item != ary[...
      Their solution works!!
      Convert to a String
      var out = "";
      for (var i = 0, nums = value.split(" "); i < nums.length; i++) {
      out += String.fromCharCode(parseInt(nums[i], 16));
      return out;
      Convert to an integer...
      var out = "";
      var int_out = 0;
      int_out=parseInt(out);
      return int_out;
