We use a small program called "rwtest", to test write and read speed on a nfs mount. It's output is like the following:
I've written the following userparameter for it:
When I use "zabbix_get" from the proxy server I get the following weird behaviour:
And in the agent log with debug level 4 I see this:
On the command line all the commands work perfectly, but when using zabbix_get they don't!?
I've tried "echoing" the result to eliminate the influence of the "rwtest" program, but I get the same result. I even tried reversing the output of the "rwtest" program before "grepping" to see if it was only displaying the top line, but again... the same result. It will only display the results from "open" and not the rest.
I've kinda run out of things to try, so I was hoping someone here could help me with this very weird behaviour.
open: 140082 microseconds read: 25692 microseconds close: 470 microseconds open: 3890 microseconds write: 742 microseconds close: 29436 microseconds
UserParameter=readtest[*],rwtest /home/homedir-request/rwtest/rwtest.$(hostname -f) 2> /dev/null | grep -m1 "$1" | egrep -o "[[:digit:]]{0,9}"
root@zabbix_proxy:~# zabbix_get -s myhost -k "readtest[open]" 2240 root@zabbix_proxy:~# zabbix_get -s myhost -k "readtest[read]" root@zabbix_proxy:~# zabbix_get -s myhost -k "readtest[close]"
$1=open:
11658:20151126:165115.014 Requested [readtest[open]]
11658:20151126:165115.014 In zbx_popen() command:'rwtest /home/homedir-request/rwtest/rwtest.$(hostname -f) 2> /dev/null | grep -m1 "open" | egrep -o "[[:digit:]]{0,9}"'
11658:20151126:165115.014 End of zbx_popen():7
11669:20151126:165115.014 zbx_popen(): executing script
11658:20151126:165115.022 In zbx_waitpid()
11658:20151126:165115.023 zbx_waitpid() exited, status:0
11658:20151126:165115.023 End of zbx_waitpid():11669
11658:20151126:165115.023 Run remote command [rwtest /home/homedir-request/rwtest/rwtest.$(hostname -f) 2> /dev/null | grep -m1 "open" | egrep -o "[[:digit:]]{0,9}"] Result [4] [2240]...
11658:20151126:165115.023 Sending back [2240]
$1=close
11660:20151126:165118.789 Requested [readtest[close]]
11660:20151126:165118.789 In zbx_popen() command:'rwtest /home/homedir-request/rwtest/rwtest.$(hostname -f) 2> /dev/null | grep -m1 "close" | egrep -o "[[:digit:]]{0,9}"'
11660:20151126:165118.789 End of zbx_popen():7
11674:20151126:165118.790 zbx_popen(): executing script
11660:20151126:165118.798 In zbx_waitpid()
11660:20151126:165118.798 zbx_waitpid() exited, status:1
11660:20151126:165118.798 End of zbx_waitpid():11674
11660:20151126:165118.798 Run remote command [rwtest /home/homedir-request/rwtest/rwtest.$(hostname -f) 2> /dev/null | grep -m1 "close" | egrep -o "[[:digit:]]{0,9}"] Result [0] []...
11660:20151126:165118.798 Sending back []
