zabbix agent2 oracle monitoring always connects to oracle 1521 (default) port
  • bartek.sojka@rebit.pl
    • Jan 2022
    Hi, I have oracle server set up on non-default port, wanted to have it monitored by zabbix agent2 installed on the same machine, however it always connects to standard 1521.
    Macro setup on zabbix server:
    {$ORACLE.CONNSTRING}=tcp://localhost:52482
    {$ORACLE.USER}=ZABBIX
    {$ORACLE.PASSWORD}=<mypassword for ZABBIX oracle user>
    {$ORACLE.SERVICE}=kalypso
    Fatal NI connect error 12541, connecting to:
    (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=localhos t)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=ORA)(CID =(PROGRAM=zabbix_agent2)(HOST=kalypso)(USER=zabbix )))(CONNECT_TIMEOUT=3)(RETRY_COUNT=0))
    TNS-12541: TNS:no listener
    agent log: [Oracle] Connection failed: ORA-12541: TNS:no listener.
    can anyone help?
    spent whole sunday trying to sort it out...
    Versions:
    Oracle 19
    Zabbix 6
    CentOS 8
    • Jan 2022
    finally managed to have it working, case closed
      • 4996
      And the problem was... ? You could help someone else with describing your solution...
        • Jan 2022
        i was configuring macros for oracle on server instead of host, i.e. in Administration->General->Macros menu. When i set those up in host definitions (Macros tab) everything started to work perfectly
