Password Azure Appliance
  • RobF
    • Nov 2015
    Hello All!
    I just setup the Azure Apliance 2.4.6 (10 august 2015) in Azure and everything looks fine.
    I'm able to login using te default credentials provided in the documentation.
    However, when i try to Login using SSH to the box, the default Appliance credentials don't work. According to the 2.4 documentation should be zabbix:zabbix or root:zabbix
    Neither of those work.
    I also deployed the same VHD to my own Hyper-V box to try to login to the console. This is the same VHD uploaded to Azure and this VM has the same problem, so logging in is impossible.
    So it looks like there is wrong information in the documentation.
    Does anybody know which (root) credentials to use for this appliance?
    Thanks in advance!
