Hi everybody
I'm having some issue with the update graph function in zabbix before 2.2.10 and now with 2.4.7.
When I try to rename the grapsh or modify some items in an already created grapsh the php interface say:
Details:
No permissions to referred object or it does not exist!
And in the bottom of the page I get
reset() expects parameter 1 to be array, null given [graphs.php:568 → reset() in /var/www/zabbix-2.4.7/graphs.php:568]
Undefined index: hostid [ in /var/www/zabbix-2.4.7/graphs.php:571]
Undefined index: name [ in /var/www/zabbix-2.4.7/graphs.php:572]
Undefined index: key_ [ in /var/www/zabbix-2.4.7/graphs.php:573]
Undefined index: flags [ in /var/www/zabbix-2.4.7/graphs.php:574]
In other cases I get
Error in query [UPDATE graphs_items SET gitemid='10010000000007301', graphid='10010000000003032', itemid='10010000000027440', sortorder='0', type='0', calc_fnc='2', drawtype='0', yaxisside='0', color='00C800' WHERE gitemid='10010000000007301'] [Cannot add or update a child row: a foreign key constraint fails (`zabbix`.`graphs_items`, CONSTRAINT `c_graphs_items_1` FOREIGN KEY (`graphid`) REFERENCES `graphs` (`graphid`) ON DELETE CASCADE)]
SQL statement execution has failed "UPDATE graphs_items SET gitemid='10010000000007301', graphid='10010000000003032', itemid='10010000000027440', sortorder='0', type='0', calc_fnc='2', drawtype='0', yaxisside='0', color='00C800' WHERE gitemid='10010000000007301'".
The server was created in "node mode" but there was only a single node (not a real DM setup), now it was changed to a single node environment but the problem remains.
PS please notice how in the forth screenshot it change also the items selected automatically (I've not changed the items)
The environment:
CentOS Linux release 7.1.1503 (64bit)
PHP 5.4.16
MariaDB Server 5.5.44
Zabbix server v2.4.7 (revision 56694) (manually compiled)
Details:
The environment:
PHP 5.4.16
