Zabbix Server is crashing on startup
  • justnwaters
    • Jan 2022
    I increased log level to 5. Here is the output:
    Not sure if its related to upgrading to 5.4 because I was able to configure things. Though after awhile I started noticing notifications that zabbix server wasn't running. I thought it was just a front-end glitch but after awhile I noticed the graphs weren't being populated with new data.
     16566:20220127:175918.796 Starting Zabbix Server. Zabbix 5.4.9 (revision d81e50696f).
     16566:20220127:175918.796 ****** Enabled features ******
     16566:20220127:175918.796 SNMP monitoring:           YES
     16566:20220127:175918.796 IPMI monitoring:           YES
     16566:20220127:175918.796 Web monitoring:            YES
     16566:20220127:175918.796 VMware monitoring:         YES
     16566:20220127:175918.796 SMTP authentication:       YES
     16566:20220127:175918.796 ODBC:                      YES
     16566:20220127:175918.796 SSH support:               YES
     16566:20220127:175918.797 IPv6 support:              YES
     16566:20220127:175918.797 TLS support:               YES
     16566:20220127:175918.797 ******************************
     16566:20220127:175918.797 using configuration file: /etc/zabbix/zabbix_server.conf
     16566:20220127:175918.797 In zbx_load_modules()
     16566:20220127:175918.797 End of zbx_load_modules():SUCCEED
     16566:20220127:175918.797 In init_database_cache()
     16566:20220127:175918.797 In zbx_mem_create() param:'HistoryCacheSize' size:16777216
     16566:20220127:175918.797 valid user addresses: [0x7f9e49947168, 0x7f9e4a946ff0] total size: 16776840
     16566:20220127:175918.797 End of zbx_mem_create()
     16566:20220127:175918.797 In zbx_mem_create() param:'HistoryIndexCacheSize' size:4194304
     16566:20220127:175918.797 valid user addresses: [0x7f9e49547178, 0x7f9e49946ff0] total size: 4193912
     16566:20220127:175918.797 In init_trend_cache()
     16566:20220127:175918.797 In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend cache' param:'TrendCacheSize'
     16566:20220127:175918.797 End of zbx_mem_required_size() size:414
     16566:20220127:175918.797 In zbx_mem_create() param:'TrendCacheSize' size:4194304
     16566:20220127:175918.797 valid user addresses: [0x7f9e49147168, 0x7f9e49546ff0] total size: 4193928
     16566:20220127:175918.797 End of init_trend_cache()
     16566:20220127:175918.797 End of init_database_cache()
     16566:20220127:175918.797 In init_configuration_cache() size:8388608
     16566:20220127:175918.797 In zbx_mem_create() param:'CacheSize' size:8388608
     16566:20220127:175918.797 valid user addresses: [0x7f9e48947168, 0x7f9e49146ff0] total size: 8388232
     16566:20220127:175918.797 End of init_configuration_cache()
     16566:20220127:175918.797 In init_selfmon_collector()
     16566:20220127:175918.797 init_selfmon_collector() size:13384
     16566:20220127:175918.798 End of init_selfmon_collector() collector:0x7f9e562df000
     16566:20220127:175918.798 In zbx_vc_init()
     16566:20220127:175918.798 In zbx_mem_required_size() size:0 chunks_num:1 descr:'value cache size' param:'ValueCacheSize'
     16566:20220127:175918.798 End of zbx_mem_required_size() size:419
     16566:20220127:175918.798 In zbx_mem_create() param:'ValueCacheSize' size:8388608
     16566:20220127:175918.798 valid user addresses: [0x7f9e48147168, 0x7f9e48946ff0] total size: 8388232
     16566:20220127:175918.798 End of zbx_mem_create()
     16566:20220127:175918.798 End of zbx_vc_init()
     16566:20220127:175918.798 In zbx_tfc_init()
     16566:20220127:175918.798 In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend function cache size' param:'TrendFunctionCacheSize'
     16566:20220127:175918.798 End of zbx_mem_required_size() size:436
     16566:20220127:175918.798 In zbx_mem_create() param:'TrendFunctionCacheSize' size:4194304
     16566:20220127:175918.798 valid user addresses: [0x7f9e47d47180, 0x7f9e48146ff0] total size: 4193904
     16566:20220127:175918.798 zbx_tfc_init(): slots:49925
     16566:20220127:175918.798 End of zbx_tfc_init():
     16566:20220127:175918.798 In zbx_db_get_database_type()
     16566:20220127:175918.798 In DBconnect() flag:0
     16566:20220127:175918.802 End of DBconnect():0
     16566:20220127:175918.802 query [txnlev:0] [select userid from users limit 1]
     16566:20220127:175918.803 there is at least 1 record in "users" table
     16566:20220127:175918.803 End of zbx_db_get_database_type():ZBX_DB_SERVER
     16566:20220127:175918.803 In DBconnect() flag:0
     16566:20220127:175918.803 End of DBconnect():0
     16566:20220127:175918.803 In zbx_dbms_version_extract()
     16566:20220127:175918.803 End of zbx_dbms_version_extract() version:50736
     16566:20220127:175918.803 In DBcheck_version()
     16566:20220127:175918.804 End of DBconnect():0
     16566:20220127:175918.804 query [txnlev:0] [show tables like 'dbversion']
     16566:20220127:175918.804 query [txnlev:0] [select mandatory,optional from dbversion]
     16566:20220127:175918.804 current database version (mandatory/optional): 05040000/05040001
     16566:20220127:175918.804 required mandatory version: 05040000
     16566:20220127:175918.804 End of DBcheck_version():SUCCEED
     16566:20220127:175918.804 In DBflush_version_requirements()
     16566:20220127:175918.804 In DBconnect() flag:0
     16566:20220127:175918.805 End of DBconnect():0
     16566:20220127:175918.805 query without transaction detected
     16566:20220127:175918.805 query [txnlev:0] [update config set dbversion_status='[{"database":"MySQL","current_version":"5.07.36","m in_version":"5.07.28","max_version":"8.00.x","flag ":0}]']
     16566:20220127:175918.815 End of DBflush_version_requirements()
     16566:20220127:175918.815 In DBconnect() flag:0
     16566:20220127:175918.815 End of DBconnect():0
     16566:20220127:175918.815 query [txnlev:0] [select default_character_set_name,default_collation_name from information_schema.SCHEMATA where schema_name='zabbix']
     16566:20220127:175918.815 query [txnlev:0] [select count(*) from information_schema.`COLUMNS` where table_schema='zabbix' and data_type in ('text','varchar','longtext') and (character_set_name not in ('utf8','utf8mb3') or collation_name not in ('utf8_bin','utf8mb3_bin'))]
     16566:20220127:175918.821 In DBcheck_double_type()
     16566:20220127:175918.821 In DBconnect() flag:0
     16566:20220127:175918.821 End of DBconnect():0
     16566:20220127:175918.821 query [txnlev:0] [select count(*) from information_schema.columns where table_schema='zabbix' and column_type='double' and ((lower(table_name)='trends' and (lower(column_name) in ('value_min', 'value_avg', 'value_max'))) or (lower(table_name)='history' and lower(column_name)='value'))]
     16566:20220127:175918.822 End of DBcheck_double_type()
     16566:20220127:175918.822 In DBconnect() flag:0
     16566:20220127:175918.822 End of DBconnect():0
     16566:20220127:175918.823 query [txnlev:0] [select configid,instanceid from config order by configid]
     16566:20220127:175918.823 server #0 started [main process]
     16572:20220127:175918.824 server #1 started [configuration syncer #1]
     16572:20220127:175918.824 zbx_setproctitle() title:'configuration syncer [connecting to the database]'
     16572:20220127:175918.824 In DBconnect() flag:0
     16572:20220127:175918.824 End of DBconnect():0
     16572:20220127:175918.825 zbx_setproctitle() title:'configuration syncer [syncing configuration]'
     16572:20220127:175918.825 In DCsync_configuration()
     16572:20220127:175918.825 query [txnlev:0] [select objectid,type,clock,ns from trigger_queue]
     16572:20220127:175918.825 query [txnlev:0] [select discovery_groupid,snmptrap_logging,severity_name_0 ,severity_name_1,severity_name_2,severity_name_3,s everity_name_4,severity_name_5,hk_events_mode,hk_e vents_trigger,hk_events_internal,hk_events_discove ry,hk_events_autoreg,hk_services_mode,hk_services, hk_audit_mode,hk_audit,hk_sessions_mode,hk_session s,hk_history_mode,hk_history_global,hk_history,hk_ trends_mode,hk_trends_global,hk_trends,default_inv entory_mode,db_extension,autoreg_tls_accept,compre ssion_status,compress_older,instanceid,default_tim ezone from config order by configid]
     16572:20220127:175918.825 query [txnlev:0] [select tls_psk_identity,tls_psk from config_autoreg_tls order by autoreg_tlsid]
     16572:20220127:175918.825 In DCsync_config()
     16572:20220127:175918.825 End of DCsync_config()
     16572:20220127:175918.825 In DCsync_autoreg_config()
     16572:20220127:175918.825 End of DCsync_autoreg_config()
     16572:20220127:175918.825 query [txnlev:0] [select hostid,templateid from hosts_templates order by hostid]
     16572:20220127:175918.826 query [txnlev:0] [select globalmacroid,macro,value,type from globalmacro]
     16572:20220127:175918.826 query [txnlev:0] [select m.hostmacroid,m.hostid,m.macro,m.value,m.type from hostmacro m inner join hosts h on m.hostid=h.hostid where h.flags<>2]
     16572:20220127:175918.828 query [txnlev:0] [select * from host_tag]
     16572:20220127:175918.829 In DCsync_htmpls()
     16572:20220127:175918.829 End of DCsync_htmpls()
     16572:20220127:175918.829 In DCsync_gmacros()
     16572:20220127:175918.829 End of DCsync_gmacros()
     16572:20220127:175918.829 In DCsync_hmacros()
     16572:20220127:175918.833 End of DCsync_hmacros()
     16572:20220127:175918.833 In DCsync_host_tags()
     16572:20220127:175918.833 End of DCsync_host_tags()
     16572:20220127:175918.833 In DCsync_kvs_paths()
     16572:20220127:175918.833 End of DCsync_kvs_paths()
     16572:20220127:175918.833 query [txnlev:0] [select hostid,proxy_hostid,host,ipmi_authtype,ipmi_privil ege,ipmi_username,ipmi_password,maintenance_status ,maintenance_type,maintenance_from,status,name,las taccess,tls_connect,tls_accept,tls_issuer,tls_subj ect,tls_psk_identity,tls_psk,proxy_address,auto_co mpress,maintenanceid from hosts where status in (0,1,5,6) and flags<>2]
     16572:20220127:175918.834 query [txnlev:0] [select hostid,inventory_mode,type,type_full,name,alias,os ,os_full,os_short,serialno_a,serialno_b,tag,asset_ tag,macaddress_a,macaddress_b,hardware,hardware_fu ll,software,software_full,software_app_a,software_ app_b,software_app_c,software_app_d,software_app_e ,contact,location,location_lat,location_lon,notes, chassis,model,hw_arch,vendor,contract_number,insta ller_name,deployment_status,url_a,url_b,url_c,host _networks,host_netmask,host_router,oob_ip,oob_netm ask,oob_router,date_hw_purchase,date_hw_install,da te_hw_expiry,date_hw_decomm,site_address_a,site_ad dress_b,site_address_c,site_city,site_state,site_c ountry,site_zip,site_rack,site_notes,poc_1_name,po c_1_email,poc_1_phone_a,poc_1_phone_b,poc_1_cell,p oc_1_screen,poc_1_notes,poc_2_name,poc_2_email,poc _2_phone_a,poc_2_phone_b,poc_2_cell,poc_2_screen,p oc_2_notes from host_inventory]
     16572:20220127:175918.834 query [txnlev:0] [select groupid,name from hstgrp]
     16572:20220127:175918.834 query [txnlev:0] [select hg.groupid,hg.hostid from hosts_groups hg,hosts h where hg.hostid=h.hostid and h.status in (0,1) and h.flags<>2 order by hg.groupid]
     16572:20220127:175918.835 query [txnlev:0] [select maintenanceid,maintenance_type,active_since,active _till,tags_evaltype from maintenances]
     16572:20220127:175918.835 query [txnlev:0] [select maintenancetagid,maintenanceid,operator,tag,value from maintenance_tag]
     16572:20220127:175918.835 query [txnlev:0] [select t.timeperiodid,t.timeperiod_type,t.every,t.month,t .dayofweek,t.day,t.start_time,t.period,t.start_dat e,m.maintenanceid from maintenances_windows m,timeperiods t where t.timeperiodid=m.timeperiodid]
     16572:20220127:175918.836 query [txnlev:0] [select maintenanceid,groupid from maintenances_groups order by maintenanceid]
     16572:20220127:175918.836 query [txnlev:0] [select maintenanceid,hostid from maintenances_hosts order by maintenanceid]
     16572:20220127:175918.836 In DCsync_hosts()
     16572:20220127:175918.836 End of DCsync_hosts()
     16572:20220127:175918.836 In DCsync_host_inventory()
     16572:20220127:175918.836 End of DCsync_host_inventory()
     16572:20220127:175918.836 In DCsync_hostgroups()
     16572:20220127:175918.836 End of DCsync_hostgroups()
     16572:20220127:175918.836 In DCsync_hostgroup_hosts()
     16572:20220127:175918.836 End of DCsync_hostgroup_hosts()
     16572:20220127:175918.836 In DCsync_maintenances()
     16572:20220127:175918.836 End of DCsync_maintenances()
     16572:20220127:175918.836 In DCsync_maintenance_tags()
     16572:20220127:175918.836 End of DCsync_maintenance_tags()
     16572:20220127:175918.837 In DCsync_maintenance_groups()
     16572:20220127:175918.837 End of DCsync_maintenance_groups()
     16572:20220127:175918.837 In DCsync_maintenance_hosts()
     16572:20220127:175918.837 End of DCsync_maintenance_hosts()
     16572:20220127:175918.837 In DCsync_maintenance_periods()
     16572:20220127:175918.837 End of DCsync_maintenance_periods()
     16572:20220127:175918.837 query [txnlev:0] [select i.interfaceid,i.hostid,i.type,i.main,i.useip,i.ip, i.dns,i.port,i.available,i.disable_until,i.error,i .errors_from,s.version,s.bulk,s.community,s.securi tyname,s.securitylevel,s.authpassphrase,s.privpass phrase,s.authprotocol,s.privprotocol,s.contextname from interface i left join interface_snmp s on i.interfaceid=s.interfaceid]
     16572:20220127:175918.837 query [txnlev:0] [select i.itemid,i.hostid,i.status,i.type,i.value_type,i.k ey_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trapper_hos ts,i.logtimefmt,i.params,ir.state,i.authtype,i.use rname,i.password,i.publickey,i.privatekey,i.flags, i.interfaceid,ir.lastlogsize,ir.mtime,i.history,i. trends,i.inventory_link,i.valuemapid,i.units,ir.er ror,i.jmx_endpoint,i.master_itemid,i.timeout,i.url ,i.query_fields,i.posts,i.status_codes,i.follow_re directs,i.post_type,i.http_proxy,i.headers,i.retri eve_mode,i.request_method,i.output_format,i.ssl_ce rt_file,i.ssl_key_file,i.ssl_key_password,i.verify _peer,i.verify_host,i.allow_traps,i.templateid,id. parent_itemid,null from items i inner join hosts h on i.hostid=h.hostid left join item_discovery id on i.itemid=id.itemid join item_rtdata ir on i.itemid=ir.itemid where h.status in (0,1) and i.flags<>2]
     16572:20220127:175918.902 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i inner join hosts h on i.hostid=h.hostid where h.status=3]
     16572:20220127:175918.911 query [txnlev:0] [select i.itemid,i.hostid,i.templateid from items i where i.flags=2]
     16572:20220127:175918.915 query [txnlev:0] [select pp.item_preprocid,pp.itemid,pp.type,pp.params,pp.s tep,i.hostid,pp.error_handler,pp.error_handler_par ams,i.type,i.key_,h.proxy_hostid from item_preproc pp,items i,hosts h where pp.itemid=i.itemid and i.hostid=h.hostid and (h.proxy_hostid is null or i.type in (5,15,18)) and h.status in (0,1) and i.flags<>2 order by pp.itemid]
     16572:20220127:175918.944 query [txnlev:0] [select p.item_parameterid,p.itemid,p.name,p.value,i.hosti d from item_parameter p,items i,hosts h where p.itemid=i.itemid and i.hostid=h.hostid and h.status in (0,1) and i.flags<>2 order by p.itemid]
     16572:20220127:175918.945 In DCsync_interfaces()
     16572:20220127:175918.945 End of DCsync_interfaces()
     16572:20220127:175918.945 In DCsync_items()
     16572:20220127:175918.979 End of DCsync_items()
     16572:20220127:175918.979 In DCsync_template_items()
     16572:20220127:175918.981 End of DCsync_template_items()
     16572:20220127:175918.981 In DCsync_prototype_items()
     16572:20220127:175918.982 End of DCsync_prototype_items()
     16572:20220127:175918.982 In DCsync_item_preproc()
     16572:20220127:175918.984 End of DCsync_item_preproc()
     16572:20220127:175918.984 In DCsync_itemscript_param()
     16572:20220127:175918.984 End of DCsync_itemscript_param()
     16572:20220127:175918.984 query [txnlev:0] [select distinct it.itemtagid,it.itemid,it.tag,it.value from item_tag it,items i,hosts h where i.itemid=it.itemid and i.flags in (0,4) and h.hostid=i.hostid and h.status in (0,1)]
     16572:20220127:175919.019 query [txnlev:0] [select i.itemid,f.functionid,f.name,f.parameter,t.trigger id,i.hostid from hosts h,items i,functions f,triggers t where h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid and h.status in (0,1) and t.flags<>2]
     16572:20220127:175919.051 In DCsync_functions()
     16572:20220127:175919.057 End of DCsync_functions()
     16572:20220127:175919.057 query [txnlev:0] [select distinct t.triggerid,t.description,t.expression,t.error,t.p riority,t.type,t.value,t.state,t.lastchange,t.stat us,t.recovery_mode,t.recovery_expression,t.correla tion_mode,t.correlation_tag,t.opdata,t.event_name, null,null,null from hosts h,items i,functions f,triggers t where h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=t.triggerid and h.status in (0,1) and t.flags<>2]
     16572:20220127:175919.128 query [txnlev:0] [select distinct d.triggerid_down,d.triggerid_up from trigger_depends d,triggers t,hosts h,items i,functions f where t.triggerid=d.triggerid_down and t.flags<>2 and h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=d.triggerid_down and h.status in (0,1)]
     16572:20220127:175919.136 query [txnlev:0] [select r.name,e.expressionid,e.expression,e.expression_ty pe,e.exp_delimiter,e.case_sensitive from regexps r,expressions e where r.regexpid=e.regexpid]
     16572:20220127:175919.136 query [txnlev:0] [select actionid,eventsource,evaltype,formula from actions where status=0]
     16572:20220127:175919.136 query [txnlev:0] [select a.actionid,o.recovery from actions a left join operations o on a.actionid=o.actionid where a.status=0 group by a.actionid,o.recovery order by a.actionid]
     16572:20220127:175919.137 query [txnlev:0] [select c.conditionid,c.actionid,c.conditiontype,c.operato r,c.value,c.value2 from conditions c,actions a where c.actionid=a.actionid and a.status=0]
     16572:20220127:175919.137 query [txnlev:0] [select distinct tt.triggertagid,tt.triggerid,tt.tag,tt.value from trigger_tag tt,triggers t,hosts h,items i,functions f where t.triggerid=tt.triggerid and t.flags<>2 and h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=tt.triggerid and h.status in (0,1)]
     16572:20220127:175919.137 query [txnlev:0] [select correlationid,name,evaltype,formula from correlation where status=0]
     16572:20220127:175919.137 query [txnlev:0] [select cc.corr_conditionid,cc.correlationid,cc.type,cct.t ag,cctv.tag,cctv.value,cctv.operator, ccg.groupid,ccg.operator,cctp.oldtag,cctp.newtag from correlation c,corr_condition cc left join corr_condition_tag cct on cct.corr_conditionid=cc.corr_conditionid left join corr_condition_tagvalue cctv on cctv.corr_conditionid=cc.corr_conditionid left join corr_condition_group ccg on ccg.corr_conditionid=cc.corr_conditionid left join corr_condition_tagpair cctp on cctp.corr_conditionid=cc.corr_conditionid where c.correlationid=cc.correlationid and c.status=0]
     16572:20220127:175919.137 query [txnlev:0] [select co.corr_operationid,co.correlationid,co.type from correlation c,corr_operation co where c.correlationid=co.correlationid and c.status=0]
     16572:20220127:175919.137 In DCsync_triggers()
     16572:20220127:175919.160 End of DCsync_triggers()
     16572:20220127:175919.160 In DCsync_trigdeps()
     16572:20220127:175919.161 End of DCsync_trigdeps()
     16572:20220127:175919.161 In DCsync_expressions()
     16572:20220127:175919.161 End of DCsync_expressions()
     16572:20220127:175919.161 In DCsync_actions()
     16572:20220127:175919.161 End of DCsync_actions()
     16572:20220127:175919.161 In DCsync_action_ops()
     16572:20220127:175919.161 End of DCsync_action_ops()
     16572:20220127:175919.161 In DCsync_action_conditions()
     16572:20220127:175919.161 End of DCsync_action_conditions()
     16572:20220127:175919.161 In DCsync_trigger_tags()
     16572:20220127:175919.161 End of DCsync_trigger_tags()
     16572:20220127:175919.161 In DCsync_item_tags()
     16572:20220127:175919.166 End of DCsync_item_tags()
     16572:20220127:175919.166 In DCsync_correlations()
     16572:20220127:175919.166 End of DCsync_correlations()
     16572:20220127:175919.166 In DCsync_corr_conditions()
     16572:20220127:175919.166 End of DCsync_corr_conditions()
     16572:20220127:175919.166 In DCsync_corr_operations()
     16572:20220127:175919.166 End of DCsync_corr_operations()
     16572:20220127:175919.168 __mem_malloc: skipped 0 asked 24 skip_min 18446744073709551615 skip_max 0
     16572:20220127:175919.168 [file:dbconfig.c,line:102] __zbx_mem_realloc(): out of memory (requested 16 bytes)
     16572:20220127:175919.168 [file:dbconfig.c,line:102] __zbx_mem_realloc(): please increase CacheSize configuration parameter
     16572:20220127:175919.168 === memory statistics for configuration cache ===
     16572:20220127:175919.168 min chunk size: 18446744073709551615 bytes
     16572:20220127:175919.168 max chunk size:          0 bytes
     16572:20220127:175919.168 memory of total size 7295208 bytes fragmented into 68315 chunks
     16572:20220127:175919.168 of those,          0 bytes are in        0 free chunks
     16572:20220127:175919.168 of those,    7295208 bytes are in    68315 used chunks
     16572:20220127:175919.168 of those,    1093024 bytes are used by allocation overhead
     16572:20220127:175919.168 ================================
     16572:20220127:175919.168 === Backtrace: ===
     16572:20220127:175919.169 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x4e) [0x56500dcee619]
     16572:20220127:175919.169 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0x160) [0x56500dce902c]
     16572:20220127:175919.169 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1b8387) [0x56500dc6c387]
     16572:20220127:175919.169 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1c6ef9) [0x56500dc7aef9]
     16572:20220127:175919.169 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x14a8) [0x56500dc7c68f]
     16572:20220127:175919.169 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x122) [0x56500db1c09a]
     16572:20220127:175919.169 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x56500dcfefe6]
     16572:20220127:175919.169 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xbbe) [0x56500db08bf7]
     16572:20220127:175919.169 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2f5) [0x56500dcee1ec]
     16572:20220127:175919.169 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2a3) [0x56500db07f2c]
     16572:20220127:175919.169 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f9e525b3bf7]
     16572:20220127:175919.169 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2a) [0x56500db06e1a]
     16566:20220127:175919.172 One child process died (PID:16572,exitcode/signal:1). Exiting ...
     16566:20220127:175919.172 zbx_on_exit() called
     16566:20220127:175919.172 In DBconnect() flag:1
     16566:20220127:175919.173 End of DBconnect():0
     16566:20220127:175919.173 In free_database_cache()
     16566:20220127:175919.173 In DCsync_all()
     16566:20220127:175919.173 In sync_history_cache_full() history_num:0
     16566:20220127:175919.173 End of sync_history_cache_full()
     16566:20220127:175919.173 In DCsync_trends() trends_num:0
     16566:20220127:175919.173 syncing trend data...
     16566:20220127:175919.173 query [txnlev:1] [begin;]
     16566:20220127:175919.173 query [txnlev:1] [commit;]
     16566:20220127:175919.173 syncing trend data done
     16566:20220127:175919.173 End of DCsync_trends()
     16566:20220127:175919.173 End of DCsync_all()
     16566:20220127:175919.173 End of free_database_cache()
     16566:20220127:175919.173 In free_configuration_cache()
     16566:20220127:175919.173 End of free_configuration_cache()
     16566:20220127:175919.173 In zbx_vc_destroy()
     16566:20220127:175919.173 End of zbx_vc_destroy()
     16566:20220127:175919.173 In free_selfmon_collector() collector:0x7f9e562df000
     16566:20220127:175919.173 End of free_selfmon_collector()
     16566:20220127:175919.173 In zbx_unload_modules()
     16566:20220127:175919.173 End of zbx_unload_modules()
     16566:20220127:175919.173 Zabbix Server stopped. Zabbix 5.4.9 (revision d81e50696f).
  • Answer selected by justnwaters at 28-01-2022, 03:15.
    tim.mooney
    • Dec 2012
    • 1432
    It can be hard to spot if you don't know what you're looking for, but if you look carefully at the messages just before the crash, you can see:
    It's telling you that you need to modify /etc/zabbix/zabbix_server.conf and use a larger value for CacheSize.
    • tim.mooney
      • Dec 2012
      • 1432
      • justnwaters
        • Jan 2022
        Perfect! I was looking through the logs for key words like "Warning, error, fail, crash, unknown, found, find, not, etc." But I couldn't find anything. Would be nice if there was some information alongside lines like information, warning, critical, error, etc. I would have been able to solve this without expert assistance.
        Nonetheless, I 100% appreciate the quick response!
