SSL Certificate Issue Using Zabbix Agent2 Plugin
  • JWF
    • Jan 2022
    I'm fairly new to Zabbix but have been successfully rolling it out to our infrastructure & learning more & more about the product as I go.
    I ran into an issue though using the Zabbix Agent2 Web Certificate plugin.
    One of our hosts (Windows Server 2016) can't seem to verify it's SSL certificate & gets the error: 'failed to verify certificate: x509: certificate is valid for <our website>, not ​<our website>' with <our website> being the same value & Cert: Validation result says 'invalid'.
    I have tried removing & re-adding the template as well as the macro but it still gets the same result.
    When I use the command: 'zabbix_get -s <IP> -k web.certificate.get[<our website>] --tls-connect=psk --tls-psk-identity="<our ID>" --tls-psk-file=<our key>', it pulls the certificate details successfully & displays it as valid.
    Is anyone able to offer any additional troubleshooting steps that I can try?
    I'm using Zabbix 5.4 on a Ubuntu 20.04 server.
    Thanks,
    Josh
  • JWF
    • Jan 2022
    This issue appears to have resolved itself..
