Timeout only for frontend
  • markfree
    • Apr 2019
    • 875
    I'm using UserParameters to collect data from an app every hour.
    Something like this:
    $ cat /etc/zabbix/zabbix_agent2.d/zabbix_agent2.app.conf
    Timeout=10
    UserParameter=app.parm1,/usr/bin/app parm1 info
    UserParameter=app.parm2,/usr/bin/app parm2 info
    UserParameter=app.parm3,/usr/bin/app parm3
    When I try to collect that data using the item test option, Zabbix gives me an error for "app.parm3" key.
    Get value from agent failed: ZBX_TCP_READ() timed out
    "app parm3" command might take about 5s to respond; therefore, I raised the Agent2 timeout parameter.
    Now I can query my host using "zabbix_get" from Server and it works fine.
    $ zabbix_get -s 192.168.7.11 -k app.parm3
    [CURRENT] 22
    [CORRECT DATA]
    But, when testing from Zabbix frontend it keeps giving me that previous error.
    Also, the host displays the item as "not supported" with the following error.
    Timeout while executing a shell script.
    I also tried raising Agent2 timeout to 30, but did not change anything.
    Zabbix Server log displays some network errors as well, but there's no real network error.
    1117:20220131:131553.634 Zabbix agent item "app.parm3" on host "192.168.7.11" failed: first network error, wait for 15 seconds
    1117:20220131:131608.641 resuming Zabbix agent checks on host "192.168.7.11": connection restored
    1117:20220131:131612.642 Zabbix agent item "app.parm3" on host "192.168.7.11" failed: first network error, wait for 15 seconds
    1117:20220131:131627.647 resuming Zabbix agent checks on host "192.168.7.11": connection restored
    The host Agent2's displays nothing at log file.
    I can't seem to find the issue.
    Any idea?
    Btw, I'm using Zabbix 5.4.9.
  • Atsushi
    • Aug 2013
    • 2028
    Did you adjust the Timeout parameter on Zabbix server side?
    • markfree
      • Apr 2019
      • 875
      I forgot about the server side timeout. A small adjustment and that was it!
      Thanks a lot.
