I need to do some data cleanup to recover from a messy migration. API calls using trigger.get to retrieve a list of triggers in problem state returns several whereas the Zabbix frontend does not. The API in my case is erroneous. How does trigger.get determine whether a trigger is in problem state? If I had the SQL query that's executed this might be fairly easy. Anyone have any guidance for me?
"jsonrpc": "2.0",
"method": "trigger.get",
"params": {
"output": [
"triggerid",
"description",
"priority"
"filter": {
"value": 1
"sortfield": "priority",
"sortorder": "DESC"
"auth": "038e1d7b1735c6a5436ee9eae095879e",
"id": 1
-Kevin
"jsonrpc": "2.0",
"params": {
"output": [
"triggerid",
"description",
"priority"
"filter": {
"value": 1
"sortorder": "DESC"
"id": 1
-Kevin
