Zabbix-agent crash
  • dimebag
    • Dec 2015
    Zabbix-agent crash
    Hello
    I have installed zabbix agent on nearly 20 of our servers
    It is working perfectly except one of our servers which the agent keeps crashing randomly
    Part of log file
    PHP Code:
     22848:20151203:201840.753 collector [idle 1 sec]
    22850:20151203:201841.026 listener #1 [processing request]
    22850:20151203:201841.026 Requested [exim.queue]
    22850:20151203:201841.026 In zbx_popen() command:'/usr/sbin/exim -bpc'
    22850:20151203:201841.026 End of zbx_popen():7
     30466
    :20151203:201841.026 zbx_popen(): executing script
     22850
    :20151203:201841.060 In zbx_waitpid()
    22850:20151203:201841.060 zbx_waitpid() exited, status:0
     22850
    :20151203:201841.060 End of zbx_waitpid():30466
     22850
    :20151203:201841.060 EXECUTE_STR() command:'/usr/sbin/exim -bpc' len:2 cmd_result:'42'
    22850:20151203:201841.060 Sending back [42]
    22850:20151203:201841.061 listener #1 [waiting for connection]
    22847:20151203:201841.083 One child process died (PID:22853,exitcode/signal:9). Exiting ...
    22847:20151203:201841.083 zbx_on_exit() called
     22850
    :20151203:201841.083 Got signal [signal:15(SIGTERM),sender_pid:22847,sender_uid:495,reason:0]. Exiting ...
    22851:20151203:201841.083 Got signal [signal:15(SIGTERM),sender_pid:22847,sender_uid:495,reason:0]. Exiting ...
    22848:20151203:201841.083 Got signal [signal:15(SIGTERM),sender_pid:22847,sender_uid:495,reason:0]. Exiting ...
    22852:20151203:201841.084 Got signal [signal:15(SIGTERM),sender_pid:22847,sender_uid:495,reason:0]. Exiting ...
    zabbix_agentd [22847]: Error on thread waiting.
    22847:20151203:201841.084 Zabbix Agent stopped. Zabbix 2.4.7 (revision 56694).
    22847:20151203:201841.084 In unload_modules()
    I tried reinstalling and updating agent but it did not help
    OS is centos 6.7 and it is 64 bit kernel
    It is exactly the same as our others servers but i could not find what is the issue
    Installed zabbix package
    PHP Code:
    root@res2:[~] rpm -qa | grep zabbix
    zabbix
    -release-2.4-1.el6.noarch
    zabbix
    -agent-2.4.7-1.el6.x86_64
    zabbix
    -2.4.7-1.el6.x86_64
    Regards
  • geniepage
    • Sep 2015
    • 34
    Hello all,
    I ahve the same and similar problem on some aix servers. I wrote script which checking agent, but it is not conceptual solution. Have someone idea how to debug it? I can use it also on aix if you know it in linux.
    Regards
    Geni
    • jstefano
      • Sep 2015
      • 30
      Originally posted by dimebag
      Hello
      It is working perfectly except one of our servers which the agent keeps crashing randomly ...
      .....OS is centos 6.7 and it is 64 bit kernel
      Regards
      I have exactly the same problem after our KVM host was upgraded to CentOS 6.7 BTW, all VMs are at CentOS 6.7 as well and agent is dying after 5 minutes. Anybody has any idea, please?
      • Colttt
        • Mar 2009
        • 878
        please run zabbix-log in debug mode!
        and post the output! if the logfile not clear, please create a bug report and post the TicketNumber here..
        Debian-User
        Sorry for my bad english
        • jstefano
          • Sep 2015
          • 30
          https://support.zabbix.com/browse/ZBX/
          Thank you, sir! Appreciate your help a lot! Attaching log here...
          • Colttt
            • Mar 2009
            • 878
            Sir?! wow
            ok, ehm it looks like a bug, please create one and attach the log-file..
            Debian-User
            • jstefano
              • Sep 2015
              • 30
              Sir?! wow
              Thanks a lot for the reply, and sorry for the title "sir" in case you actually are a female!
              • dimebag
                • Dec 2015
                Has there been any update on this ?
                I did not find it on bug report section
                regards
