Hi all,
I've create host discovery rule with 2 SNMP checks for 2 different SNMP OID. The first one(iso.3.6.1.2.1.1.5.0) I needed for the uniqueness criteria - to catch the devices with two or more IP addresses. The second check(iso.3.6.1.2.1.1.1.0), I used in action to link template based on received value by this second check. The uniqueness criteria is set to SNMPv3 agent "iso.3.6.1.2.1.1.5.0". The problem is that in Monitoring->Discovery, the discovered hosts(IPs) are grouped(indented) by iso.3.6.1.2.1.1.1.0(second check).
Is this a bug or normal behaviour?
