Issue with web.certificate.get and ssl monitoring
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    I am trying to use web.certificate.get
    One of the sites I am trying to connect to needs a client cert. I don't want to allocate zabbix one.
    I don't think it needs it. it might fail to connect but it should have the server cert and there be able to validate it / check it
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 152
    What error message do you get?
    • Alex_SYB
      • Feb 2012
      • 133
      TLS handshake error error code 40.
      it fails to complete tls handshake because a client cert is required. I don't plan on giving zabbix a client cert. But it shouldn't need it as it has the server cert.
      • Glencoe
        Zabbix developer
        • Oct 2019
        • 152
        At a glance, this seems like a reasonable suggestion. Can you please add a feature request about it?
