zabbix pre-requisites fail for PHP gd
  • ketanb81
    • Dec 2015
    Hello everyone,
    new to Zabbix, got it installed on CentOS 7. Having some issues with Pre-Requisites check on the web gui.
    I am getting PHP gd fail due to 'unknown' current value and also getting 'off' on other PHP gd related item such as:
    PHP gd PNG support (off)
    PHP gd JPEG support (off)
    PHP gd FreeType Support (off)
    Any help getting pass this would be much appreciated.
    thank you
    ketanb81
  • Atsushi
    • Aug 2013
    • 2028
    How did you install to the Zabbix and PHP?
    If you are installing using the CentOS package, you only need to install the php-gd package.
    If you are installing the PHP from source with configure, perhaps that option is missing or the setting of PHP is missing.
    • ketanb81
      • Dec 2015
      I installed using the PHP rpm packages. Installed the latest php-gd rpm as well.
