Regex Not Working
  • justnwaters
    • Jan 2022
    Regex Not Working
    I went through and manually deleted all the rules for services that were creating problems I didn't want after setting my expressions. There were so many services I wanted to stop warnings from that I had to split the expression. Below is an example of a service that created an alert even though the test shows it coming back FALSE.
    I even removed the rule for startup delayed. But that doesn't seem to have helped.
    What did I miss here?
    • 4996
    "I think" you edited global regex, but your template is not using it... For a while already those macros are in template and you should edit it there... Or make that template use global expression.
