CAutoloader::loadClass() could not obtain parameters since upgrading to 6.0.0
  • akschu
    • May 2006
    • 17
    Since the upgrade to 6.0.0 I can't update the trigger prototypes. I get this error in my apache web server log and it sends 500 Internal Server Error to the browser.
    [Wed Feb 16 14:42:59.161799 2022] [php7:error] [pid 24408:tid 139674702026496] [client 192.168.7.98:64534] PHP Fatal error: CAutoloader::loadClass(): could not obtain parameters for parsing in Unknown on line 0, referer: <HOSTNAME>/trigger_prototypes.php?form=update&parent_discover yid=36079&triggerid=17177&context=template
  • akschu
    • May 2006
    • 17
    The page I'm trying to load is: Request URL: https://<HOSTNAME>/zabbix.php?sid=9b519501c4ffe677&action=popup.trigg erexpr
    • akschu
      • May 2006
      • 17
      Figured it out. I was on php 7.2. After upgrading to 7.4 it works fine. The checker at setup.php said 7.2 is fine, that no longer appears to be true.
        • 4996
        Requirements say
        PHP 7.2.5 or later
        If it just verifies until 7.2...then it should try better, I think... From 5.0LTS min version was upped from 7.2.0 to 7.2.5.
