Problems with dynamic paging file size in Windows
  • XorroX
    • May 2015
    Hello Guys,
    We are using Zabbix 2.4.5 and monitor the Zabbix Agent item "system.swap.size[,free]" on Windows Hosts.
    Sometimes it occurs, that Zabbix shows 0Byte for this item.
    Do you have any idea why this is happening?
    Thanks for your help!
  • SwitchZabbix
    • Dec 2015
    • 17
    Pagefile Clearing
    May at shutdown time if you enabled ClearPageFileAtShutdown :
    This setting clears the pagefile for security reason.
    • XorroX
      • May 2015
      No shutdown
      Thanks for your feedback, but unfortunately this is not the solution for our case.
      The affected servers are never shut down...
      Any other ideas?
      Thanks!
      • SwitchZabbix
        • Dec 2015
        • 17
        Performance counters
        Hi again,
        So it could be an issue with performance counters. Is the CPU really high when you get 0 for the pagefile size?
        • XorroX
          • May 2015
          Normal Values
          Thanks again for your feedback!
          But both RAM and CPU have normal values when this "error" appears.
          • SwitchZabbix
            • Dec 2015
            • 17
            Which perf counter?
            Which perf counter are you using?
            • XorroX
              • May 2015
              No perf counter
              We are not using perf counter in this context.
              These items are configured as Zabbix Agent items.
              • SwitchZabbix
                • Dec 2015
                • 17
                Perf counters and Zabbix
                In fact it does.
                And it seems the calculation made to find values are not so simple to get. A bug is open in 2.4.1 https://support.zabbix.com/browse/ZBX-9619
                For more information, to calculate the value accurately: https://support.microsoft.com/en-us/kb/2860880
                And the API used to find the base of the calculation: https://msdn.microsoft.com/en-us/lib...=vs.85%29.aspx
                I think you have to wait the bug ZBX-9619 to be closed.
