Hello all
I'm testing upgrade DB Postgresql 13.6 with TimescaleDB 2.3.1. On test server i have recovered DB and following example from Zabbix upgrade documents with one example on table "history_uint" . This example is fine , but i'm not DB guru and now i'm failing on table "history_log" .
Used example but i modify for TEMP TABLE because is different structure . But script no create compression job id and timescaledb_information.jobs is like this :
job_id | application_name | schedule_interval | max_runtime | max_retries | retry_period | proc_schema | proc_name | owner | scheduled | config | next_start | hypertable_schema | hypertable_name
1 | Telemetry Reporter [1] | 24:00:00 | 00:01:40 | -1 | 01:00:00 | _timescaledb_internal | policy_telemetry | postgres | t | | 2022-02-22 15:20:10.146532+01 | |
1027 | Compression Policy [1027] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 7, "compress_after": "871200"} | 2022-02-23 14:24:07.505675+01 | public | trends_uint
1026 | Compression Policy [1026] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 6, "compress_after": "871200"} | 2022-02-23 14:24:07.519807+01 | public | trends
1025 | Compression Policy [1025] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 3, "compress_after": "871200"} | 2022-02-23 14:24:10.82734+01 | public | history_log_old
1024 | Compression Policy [1024] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 4, "compress_after": "871200"} | 2022-02-23 14:24:12.637611+01 | public | history_text_old
1023 | Compression Policy [1023] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 5, "compress_after": "871200"} | 2022-02-23 14:24:16.015155+01 | public | history_str_old
1021 | Compression Policy [1021] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 1, "compress_after": "871200"} | 2022-02-23 14:25:08.925029+01 | public | history_old
1022 | Compression Policy [1022] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 2, "compress_after": "871200"} | 2022-02-23 14:31:00.486394+01 | public | history_uint_old
Script :
-- Verify that there is enough space to allow export of uncompressed data
select sum(before_compression_total_bytes)/1024/1024 as before_compression_total_mbytes, sum(after_compression_total_bytes)/1024/1024 as after_compression_total_mbytes FROM chunk_compression_stats('history_old');
-- Export data
\copy (select * from history_log_old) TO '/var/lib/postgresql/tables/history_log.csv' DELIMITER ',' CSV
CREATE TEMP TABLE temp_history_log (
itemid bigint NOT NULL,
clock integer DEFAULT '0' NOT NULL,
timestamp integer DEFAULT '0' NOT NULL ,
source varchar(64) DEFAULT '' NOT NULL ,
severity integer DEFAULT '0' NOT NULL ,
value text DEFAULT '0' NOT NULL,
logeventid integer DEFAULT '0' NOT NULL ,
ns integer DEFAULT '0' NOT NULL
-- Import data
\copy temp_history_log FROM '/var/lib/postgresql/tables/history_log.csv' DELIMITER ',' CSV
-- Create hypertable and populate it
select create_hypertable('history_log', 'clock', chunk_time_interval => 86400, migrate_data => true);
INSERT INTO history_log SELECT * FROM temp_history_log ON CONFLICT (itemid,clock,ns) DO NOTHING;
-- Enable compression
select set_integer_now_func('history_log', 'zbx_ts_unix_now', true);
alter table history_log set (timescaledb.compress,timescaledb.compress_segment by='itemid',timescaledb.compress_orderby='clock,ns ');
-- Substitute your schema in hypertable_schema
-- Job id will returned, it should be passed to run_job
select add_compression_policy('history_log', (
select extract(epoch from (config::json->>'compress_after')::interval) from timescaledb_information.jobs where application_name like 'Compression%%' and hypertable_schema='public' and hypertable_name='history_log'
)::integer
select alter_job((select job_id from timescaledb_information.jobs where hypertable_schema='public' and hypertable_name='history_log'), scheduled => true);
-- Run compression job
call run_job(<JOB_ID>);
-- May show 'NOTICE: no chunks for hypertable public.history that satisfy compress chunk policy', it is fine.
Output from script :
zabbix=# \i /var/lib/postgresql/upgrage_history_log.sql
before_compression_total_mbytes | after_compression_total_mbytes
19412.445312500000 | 1161.7734375000000000
(1 row)
COPY 1351164
CREATE TABLE
COPY 1351164
create_hypertable
(15,public,history_log,t)
(1 row)
INSERT 0 1351164
(1 row)
ALTER TABLE
(1 row)
psql:/var/lib/postgresql/upgrage_history_log.sql:35: ERROR: job ID cannot be NULL
psql:/var/lib/postgresql/upgrage_history_log.sql:38: ERROR: syntax error at or near "<"
LINE 1: call run_job(<JOB_ID>);
Anybody help me with this problem or somebody has working scripts for DB upgrade ?
With best regards
Michal
Script :
-- Export data
-- Import data
)::integer
(1 row)
COPY 1351164
CREATE TABLE
COPY 1351164
create_hypertable
(1 row)
INSERT 0 1351164
(1 row)
ALTER TABLE
(1 row)
With best regards
Michal
