Can't install Zabbix 6.0 + Managed Postgres (by Yandex Cloud)
  • SlipKo
    • Feb 2022
    Hello!
    I want to install Zabbix 6.0 on VM (in the Yandex Cloud (YC) ) and for DB I want to use Managed PostgreSQL by YC. But for connect to YC PSQL Cluster application need to use CA.crt from ~/.postgresql/root.crt.
    After install zabbix packages on Debian 11 I open "web setup page" and go to page "Configure DB connection". But zabbix couldn't connect to PSQL cluster:
Name:	Снимок экрана 2022-02-22 в 17.33.52.png
    /var/log/zabbix/zabbix_server.log contains next strings:
    14411:20220222:143109.629 database is down: reconnecting in 10 seconds
    14411:20220222:143119.635 [Z3001] connection to database 'zabbix' failed: [0] ERROR: odyssey: cacb93f0ddf39: incorrect password
    How to connect zabbix to PSQL with ca.crt verification?
    • 4996
    If you read, what's on your screen, then it tells you exactly, what to do ... "Please create database manually and set the configuration parameters for connection to this database".
    https://www.zabbix.com/documentation.../zabbix_server should help you (DBTLS.... parameters).
