Zabbix 6.0.0 - SQL querries get stuck when running on Mariadb 10.6
  • Dirt
    • Feb 2022
    • 9
    Running Zabbix Server 6.0.0 on Ubuntu 20.04.4. 4 powerful cores, 8GB RAM, SSD RAID. When installed with Mariadb 10.6 queries get stuck as soon as zabbix-server started.
    CPU load on one core as also 100% and frontend not responding at that moment. With empty server query sometimes get through, but as soon as I add several hosts it completely locks out.
    Absolutely no errors in syslog or zabbix-server log.
    Non of cache optimizations help and with mariadb v.10.5 things get back to normal.
    Can this be easily solved?
    Click image for larger version  Name:	querry hang3.png Views:	0 Size:	173.8 KB ID:	440404
  • pgatty
    • Feb 2022
    • 14
    I'm running 10.6 on Ubuntu 20.04 and it runs just fine. FYI... this wasn't a fresh install. I upgraded from 10.3.
    • Dirt
      • Feb 2022
      • 9
      I have a clean install, and did it several time, problem absolutely persistent. :/
      "select distinct tt.triggertagid....." query constantly gets stuck and non other queries go through until it passes.
      Click image for larger version  Name:	query hang4.png Views:	0 Size:	940.9 KB ID:	440443
      • Grefusa
        • Feb 2019
        I am having the same problem. Made a new server with MariaDB 10.6, imported DB, it upgraded successfully but I have no monitoring. There is no queue on Zabbix.
        Does anybody have a solution?
        EDIT: If you clear the template and add it again, it creates the items. And then it starts monitoring the host.
        • Dirt
          • Feb 2022
          • 9
          Personally I have gave app and deployed with 10.5.
          • vso
            Zabbix developer
            • Aug 2016
            • 190
            Mentioned queries have been changed in 6.0.1 please try upgrading when it is available
