issues with active checks and TLS?
  • garryavx
    • Feb 2022
    tried to attach my logs and config for server and agent but seems I'm not allowed to upload .log files? seems weird. code blocks below of last few log entries and full config
    I setup psk encryption for two of my hosts. one of them seems to be working fine, the other I get constant errors about unencrypted connections in the logs of server. not sure why. the configs are identical except for the hostname being changed. the version of the zabbix agent installed on both hosts is also the same. removed the trouble hosted and recreated it by cloning the working one and changing the hostname.
    no good, very stumped.
    root@alpha:~# tail -f /var/log/zabbix/zabbix_agentd.log
    25876:20220225:124400.943 IPv6 support: YES
    25876:20220225:124400.943 TLS support: YES
    25876:20220225:124400.943 **************************
    25876:20220225:124400.943 using configuration file: /etc/zabbix/zabbix_agentd.conf
    25876:20220225:124400.944 agent #0 started [main process]
    25877:20220225:124400.944 agent #1 started [collector]
    25878:20220225:124400.944 agent #2 started[listener #1]
    25879:20220225:124400.945 agent #3 started[listener #2]
    25880:20220225:124400.945 agent #4 started[listener #3]
    25881:20220225:124400.945 agent #5 started [active checks #1]
    [root@zabbix ~]# tail -f /var/log/zabbix/zabbix_server.log
    1178931:20220225:185311.504 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178931:20220225:185316.517 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178930:20220225:185332.534 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178930:20220225:185337.608 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178926:20220225:185342.636 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178926:20220225:185350.648 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178928:20220225:185355.716 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178931:20220225:185406.735 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178931:20220225:185411.755 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178925:20220225:185416.768 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178925:20220225:185432.784 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178926:20220225:185437.853 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178926:20220225:185442.879 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178928:20220225:185449.886 cannot send list of active checks to "155.138.245.79": connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    1178928:20220225:185450.897 connection of type "unencrypted" is not allowed for host "alpha.auravoice.us"
    # This is a configuration file for Zabbix agent daemon (Unix)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_agentd.pid
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    ### Option: LogType
    # Specifies where log messages are written to:
    # system - syslog
    # file - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=
    LogFile=/var/log/zabbix/zabbix_agentd.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ### Option: AllowKey
    # Allow execution of item keys matching pattern.
    # Multiple keys matching rules may be defined in combination with DenyKey.
    # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    # Parameters are processed one by one according their appearance order.
    # If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Mandatory: no
    ### Option: DenyKey
    # Deny execution of items keys matching pattern.
    # Multiple keys matching rules may be defined in combination with AllowKey.
    # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    # DenyKey=system.run[*]
    ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
    # Internal alias for AllowKey/DenyKey parameters depending on value:
    # 0 - DenyKey=system.run[*]
    # 1 - AllowKey=system.run[*]
    # Mandatory: no
    ### Option: LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # LogRemoteCommands=0
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=zabbix.auravox.solutions
    ### Option: ListenPort
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StartAgents
    # Number of pre-forked instances of zabbix_agentd that process passive checks.
    # If set to 0, disables passive checks and the agent will not listen on any TCP port.
    # Mandatory: no
    # Range: 0-100
    # Default:
    # StartAgents=3
    ##### Active checks related
    ### Option: ServerActive
    # List of comma delimited IP addresses or DNS names (address:port) pairs or clusters (address:port;address2:port) of Zabbix servers and Zabbix proxies for active checks.
    # If port is not specified, default port is used.
    # Cluster nodes need be separated by semicolon.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example for multiple servers:
    # ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Example for HA:
    # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051;zabbix.cluster.node3
    # Example for HA with two clusters and one server:
    # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051,zabbix.cluster2.node1;zabbix.cluster2.n ode2,zabbix.domain
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=zabbix.auravox.solutions
    ### Option: Hostname
    # List of comma delimited unique, case sensitive hostnames.
    # Required for active checks and must match hostnames as configured on the server.
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=alpha.auravoice.us
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: HostInterface
    # Optional parameter that defines host interface.
    # Host interface is used at host auto-registration process.
    # If not defined, value will be acquired from HostInterfaceItem.
    # Mandatory: no
    # Default:
    # HostInterface=
    ### Option: HostInterfaceItem
    # Optional parameter that defines an item used for getting host interface.
    # This option is only used when HostInterface is not defined.
    # Mandatory: no
    # Default:
    # HostInterfaceItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix Server or Proxy if the buffer is full.
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log' and 'logrt' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log' or 'logrt' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # MaxLinesPerSecond=20
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve the ID of user 'zabbix':
    # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.:([0-9]+),,,,\1]
    # Now shorthand key zabbix.userid may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: AllowRoot
    # Allow the agent to run as 'root'. If disabled and the agent is started by 'root', the agent
    # will try to switch to the user specified by the User configuration option instead.
    # Has no effect if started under a regular user.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Default:
    # AllowRoot=0
    ### Option: User
    # Drop privileges to a specific, existing user on the system.
    # Only has effect if run as 'root' and AllowRoot is disabled.
    # Mandatory: no
    # Default:
    # User=zabbix
    # NOTE: This option is overriden by settings in systemd service file!
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    # Include=/usr/local/etc/zabbix_agentd.userparams.conf
    # Include=/usr/local/etc/zabbix_agentd.conf.d/
    # Include=/usr/local/etc/zabbix_agentd.conf.d/*.conf
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # The following characters are not allowed:
    # Additionally, newline characters are not allowed.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # See 'zabbix_agentd' directory for examples.
    # Mandatory: no
    # Default:
    # UserParameter=
    ### Option: UserParameterDir
    # Directory to execute UserParameter commands from. Only one entry is allowed.
    # When executing UserParameter commands the agent will change the working directory to the one
    # specified in the UserParameterDir option.
    # This way UserParameter commands can be specified using the relative ./ prefix.
    # Mandatory: no
    # Default:
    # UserParameterDir=
    ####### LOADABLE MODULES #######
    ### Option: LoadModulePath
    # Full path to location of agent modules.
    # Default depends on compilation options.
    # To see the default path run command "zabbix_agentd --help".
    # Mandatory: no
    # Default:
    # LoadModulePath=${libdir}/modules
    # Module to load at agent startup. Modules are used to extend functionality of the agent.
    # Formats:
    # LoadModule=<module.so>
    # LoadModule=<path/module.so>
    # LoadModule=</abs_path/module.so>
    # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
    # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
    # It is allowed to include multiple LoadModule parameters.
    # Mandatory: no
    # Default:
    # LoadModule=
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    # How the agent should connect to server or proxy. Used for active checks.
    # Only one value can be specified:
    # unencrypted - connect without encryption
    # psk - connect using TLS and a pre-shared key
    # cert - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    TLSConnect=psk
    ### Option: TLSAccept
    # What incoming connections to accept.
    # Multiple values can be specified, separated by comma:
    # unencrypted - accept connections without encryption
    # psk - accept connections secured with TLS and a pre-shared key
    # cert - accept connections secured with TLS and a certificate
    # Default:
    TLSAccept=psk
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    # Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    # Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    # Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ### Option: TLSPSKIdentity
    # Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    TLSPSKIdentity= zabbix
    ### Option: TLSPSKFile
    # Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    TLSPSKFile= /etc/zabbix/psk
    ####### For advanced users - TLS ciphersuite selection criteria #######
    ### Option: TLSCipherCert13
    # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
    # Override the default ciphersuite selection criteria for certificate-based encryption.
    # Mandatory: no
    # Default:
    # TLSCipherCert13=
    # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
    # Example for GnuTLS:
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # Example for OpenSSL:
    # EECDH+aRSA+AES128:RSA+aRSA+AES128
    # Mandatory: no
    # Default:
    # TLSCipherCert=
    ### Option: TLSCipherPSK13
    # Override the default ciphersuite selection criteria for PSK-based encryption.
    # Example:
    # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
    # Mandatory: no
    # Default:
    # TLSCipherPSK13=
    # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
    # kECDHEPSK+AES128:kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherPSK=
    ### Option: TLSCipherAll13
    # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
    # Example:
    # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
    # Mandatory: no
    # Default:
    # TLSCipherAll13=
    # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
    # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
    # Mandatory: no
    # Default:
    # TLSCipherAll=
    ####### For advanced users - TCP-related fine-tuning parameters #######
    ## Option: ListenBacklog
    # The maximum number of pending connections in the queue. This parameter is passed to
    # listen() function as argument 'backlog' (see "man listen").
    # Mandatory: no
    # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
    # Default: SOMAXCONN (hard-coded constant, depends on system)
    # ListenBacklog=
