Unable to change LDAP bind password
  • Mark P Thornton
    • Feb 2022
    • 10
    Response is
    Fatal error, please report to the Zabbix team
    • Incorrect value for "passwd_check_rules" field.
    • Controller: authentication.edit
    • action: authentication.edit
    • action_passw_change: authentication.edit
    • authentication_type: 0
    • change_bind_password: 1
    • db_authentication_type: 0
    • form_refresh: 1
    • http_auth_enabled: 0
    • ldap_base_dn: DC=Enactor,DC=local
    • ldap_bind_dn: CN=Svc_Zabbix,OU=Service Accounts,OU=Users,OU=Resources,DC=Enactor,DC=local
    • ldap_case_sensitive: 0
    • ldap_configured: 1
    • ldap_host: addc.enactor.local
    • ldap_port: 389
    • ldap_search_attribute: sAMAccountName
    • ldap_test_password:
    Any ideas as to how to proceed?
    Zabbix version 6.0.0. This was updated from 5.4
  • Mark P Thornton
    • Feb 2022
    • 10
    The value for passwd_check_rules is the same as for a test instance of 6.0.1, but still gets the error.
    MariaDB [zabbixdb]> select passwd_min_length, passwd_check_rules from config;
    | passwd_min_length | passwd_check_rules |
    | 8 | 8 |
    1 row in set (0.000 sec)
    I also updated the ldap_bind_password in config manually, but still failed to bind.
    Mark
