Template DB PostgreSQL password authentication failed
  • naoki
    • Mar 2022
    I'm very tired
    • Case
    ZABBIX Server : /var/log/zabbix/zabbix_server.log
    psql: FATAL: database "zbx_monitor" does not exist'
    psql: FATAL: password authentication failed for user "zbx_monitor"
    • Cause
    Template is old
    Bef : Template tooling version used: 0.39
    New : Template tooling version used: 0.41
    • Solution
    1. Delete old template "Template DB PostgreSQL"
    2. Download template for PostgreSQL.
    3. Import new template "PostgreSQL by Zabbix agent"
    • remarks setting
    1. macro $PG.PASSWORD -> none or delete
    2. vi /var/lib/zabbix/.pgpass
    127.0.0.1:5432:postgres:zbx_monitor:<passwd>
    3. vi pg_hba.conf
    host all all 127.0.0.1/32 md5
    Mark System Techno LLC
  • Atsushi
    • Aug 2013
    • 2028
    What is the detailed version of Zabbix you are using? Where exactly was the template you imported? For example, if it is a template "PostgreSQL by Zabbix agent" that uses Zabbix agent for Zabbix 6.0, it is the following URL.
    https://git.zabbix.com/projects/ZBX/...Frelease%2F6.0
    If you built your environment using the files here, you should have the macro {$PG.PASSWORD}. Did you check the inherited macro in the host settings?
    • naoki
      • Mar 2022
      ploblem at Upgrade Zabbix from 5.0 to 6.0.... :-)
      Template doesn't update (maybeeeee)
      • Podman Container Host
      # cat /etc/redhat-release
      Red Hat Enterprise Linux release 8.5 (Ootpa)
      # podman -v
      podman version 3.4.2
      • ZABBIX Server Container
      # zabbix_server -V
      zabbix_server (Zabbix) 6.0.0rc2
      Revision aa502ddaae 4 February 2022, compilation time: Feb 4 2022 13:27:18
      Copyright (C) 2022 Zabbix SIA
      License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
      This is free software: you are free to change and redistribute it according to
      the license. There is NO WARRANTY, to the extent permitted by law.
      This product includes software developed by the OpenSSL Project
      for use in the OpenSSL Toolkit (http://www.openssl.org/).
      Compiled with OpenSSL 1.1.1g FIPS 21 Apr 2020
      Running with OpenSSL 1.1.1k FIPS 25 Mar 2021
      • Postgresql DB Container
      zabbix_agentd -V
      zabbix_agentd (daemon) (Zabbix) 6.0.0rc2
      # postgres -V
      postgres (PostgreSQL) 10.17
      • naoki
        • Mar 2022
        upgrade zabbix : 2 month ago
        check start for posgresql : 5 days ago
        I didn't think it was due to the template version.
        • Atsushi
          • Aug 2013
          • 2028
          If you're using the template I've presented, you don't need to set up .pgpass. If you can't tell me which template you used and how you set it up, I wouldn't be able to help you solve the problem. Also, Zabbix 6.0 has already been officially released, so I strongly recommend that you continue to use rc2.
          why? The settings may have changed slightly depending on the template you are using. If you're using the latest template and the macro {$PG.PASSWORD} is none or deleted, you probably haven't set it up. Naturally it doesn't work.
          • naoki
            • Mar 2022
            Hi Atsushi-Kun.
            It is important to understand the manual. but manual is manual.
            Even if you understand the manual, ZABBIX may not work.
            Now ZABBIX6.0 can monitor Postgresql.
            If md5 use at pg_hba.conf and {$PG.PASSWORD} is none, zabbix-agent uses /var/lib/zabbix/.pgpass. (default home dir)
            If {$PG.PASSWORD} is none, $4({$PG.PASSWORD}) and $5({$PG.DB}) is NULL in template_db_postgresql.yaml and template_db_postgresql.conf.
            Like snmp, For High security Production System, we don't put password in ZABBIX ;-)
            In a huge project, DBmanager and monitoring manager are not the same person.
            • Atsushi
              • Aug 2013
              • 2028
              It was confirmed that it can be monitored by the method described in .pgpass without setting the macro {$PG.PASSWORD} on Zabbix 6.0.1. However, if you're using a locale other than English, the item "Status: Ping" doesn't work properly, so it seems that you need to modify the JavaScript in preprocessing to match your language.
              This is probably because the specified database name was incorrect. Did you change anything from the template?
              This should be resolved if .pgpass correctly lists zbx_monitor as the account and the corresponding password. If this doesn't help, you probably have made some changes to the template. Please try reloading the template again.
              • naoki
                • Mar 2022
                Hi Atsushi-Kun.
                Where was this sentence written?
                (0.39) - key: 'pgsql.bgwriter["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.DB}"]'
                (0.41) + key: 'pgsql.bgwriter["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.PASSW ORD}","{$PG.DB}"]'
                • Conclusion
                S1. Template at ZABBIX-server is ver 5.0.
                S2. UserParameter file at ZABBIX-agent is ver 6.0.
                UserParameter=pgsql.bgwriter[*], psql -qtAX postgresql://"$3":"$4"@"$1":"$2"/"$5" -f "/var/lib/zabbix/postgresql/pgsql.bgwriter.sql"
                S3. I didn't have the steps at Upgrade Zabbix from 5.0 to 6.0
                • Best Answer
                Reloading the template for v6.0
