Dear Zabbix Community
I am trying to get into SNMPTRAPS and have created a template with a fallback key for unknown errors.
I have modified the trigger that I can close those problems manually ones checked everything is ok.
If a problem is generated I can manually close it but it keeps reappearing as a new problem.
I removed all content from: /tmp/zabbix_traps.tmp but the problem still gets opened again.
The only "solution" I found so far was to remove and add the host again. Afterwards the problem does not reappear until a new SNMP Trap is received.
I am not sure where to look for errors. I cannot see anything in the "/var/log/zabbix/zabbix_server.log" log...
Zabbix Version: 5.4 (latest release)
Thanks.
Grimbi
Thanks.
Grimbi
