Zabbix-server 6.0 Import Template Issue
  • AnatolyZRG
    • Mar 2022
    Hi everyone.
    I'm facing an issue with the import any template (For example Template - Hikvision camera by HTTP). Zabbix Server is loading and nothing happens.
    If Check only item import, template is import successfully.
  • MaxMax
    • Mar 2022
    I have fixed this issue by changing the Max Size limit of php.ini and apache.conf. The default limit size is 3MB, did your Template size bigger than it ?
    • MaxMax
      • Mar 2022
      one more addition, you can check with Chrome Developer Tool and the console will reply any error Code then you will have a clue to handle
      • AnatolyZRG
        • Mar 2022
        MaxMax Thanks for the answer. I find this problem in "Zabbix bugs and issues" [ZBX-20650] After updating to version 6.0, template import hangs - ZABBIX SUPPORT
        it's solved problem for me.
