Zabbix-Server keeps crashing
  • Aperture-Development
    • May 2019
    Hello everyone,
    Today I upgraded from Zabbix 5.4 to 6.0, and now I am encountering a issue where the zabbix-server service keeps crashing and restarting every 30 seconds. Below is a tracelog, I am unsure if thats helpfull or not:
    https://www.toptal.com/developers/ha...emiwogilox.log
    I am thankful for any help or suggestion.
  • trisight
    • Mar 2022
    We have the same problem after upgraded zabbix from v6.0.0 to v6.0.1, logs attached.
    • miki3421
      • Feb 2021
      Here same problem. It seems related to the HA feature.
      221:20220307:104358.537 server #46 started [trigger housekeeper #1]
      222:20220307:104358.548 server #47 started [odbc poller #1]
      175:20220307:104401.792 HA manager has been paused
      7:20220307:104401.792 HA manager error: the server HA registry record has changed ownership
      7:20220307:104401.792 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x2719]. Crashing ...
      7:20220307:104401.792 ====== Fatal information: ======
      7:20220307:104401.792 program counter not available for this architecture
      • acyrulik
        • Mar 2022
        Exatcly that same problem here after upgrade from 6.0.0 to 6.0.1 Now 6.0.1 is broken and unusable.
        • Glencoe
          Zabbix developer
          • Oct 2019
          • 153
          This should be fixed in 6.0.2: https://support.zabbix.com/browse/ZBX-20697
          • miki3421
            • Feb 2021
            I've tried the versione 6.0.0 .. but I have the same result.
            • Glencoe
              Glencoe commented
              Can you please try 6.0.2rc1 and see if the problem persists?
          • miki3421
            • Feb 2021
            where I can find the version 6.0.2rc1 for zabbix/zabbix-server-pgsql on docker zabbix hub? I can't find the proper tag.
            • Glencoe
              Zabbix developer
              • Oct 2019
              • 153
              RCs are only available as tar balls here: https://cdn.zabbix.com/zabbix/source...andidates/6.0/ you'd need to compile it yourself. Packages and dockerhub images will be available once the final 6.0.2 released.
              • miki3421
                • Feb 2021
                I don't know how to do it. Do you know if there is a tutorial? Thanks
