TCP port check
  • derli1988
    • Apr 2021
    • 60
    TCP port check
    Hello everybody.
    I'm trying to monitor TCP checks on specific ports for specific IPs...
    I'm using google DNS for testing purposes...
    So far I am having great success with the below trigger...
    However, I'd like to have the alert to be triggered after some failed attempts, the way I am doing now, as soon as 1 failed check happens, I'm getting an alert...
    This could lead to false positives.
    last(/Template host1/net.tcp.service[tcp,8.8.8.8,443])=0
    Can anyone, please, tell me how I can make my checks better?
    • 4996
    For example, you can use function max().
    max (/host/key,(sec|#num)<:time shift>)
    if max value for time period X is 0 (considering, that it only returns 1 or 0), it means all checks are failed and you have an issue. If at least one check returned 1 during that period, trigger will not activate.
    • derli1988
      • Apr 2021
      • 60
      That's a very odd and different approach... I'll try it out, thanks.
        • 4996
        You can also use count(), it gives a bit different result. This allows you have some failures. Like, say, if we have 2 fails during 5m period, it is ok, but if its more, fire a trigger. It does not care if fails are after each other, it just looks for a count during a period of time
