Zabbix Native HA mode using Docker
  • kashifhafeez
    • Mar 2022
    I am using Docker Container for Zabbix 6.0. i have two zabbix servers running the same version of Zabbix server, front end, and DB. basically a clone. im trying to set up the HA mode, and have the following premasters in the zabbix_config file changed HANodeName= zabbix-ha
    NodeAddress=node01;node02
    i do not see a place to change the following setting which are needed in HA mode, but comment them out if are being used.
    #$zbx_server = '';
    #$zbx_SERVER_PORT = '';
    with the setting i do have, the server is not running. when i revert the changes back it starts to run back as normal.
    what could i be doing wrong in the docker set up?
