Zabbix Proxy - cannot send list of active checks to
  • shinmorpheus
    • Mar 2022
    • 9
    Hi guys,
    I've an issue with my second proxy,
    for all host configured on this proxy i receive the message "host not found"
    on the agent log i see :"host not found"
    I've cheked all, but I don't have idea.
    Someone can help me?
    Daniel
    Zabbix Server: 6.0.1
    zabbix Proxy: 6.0.1
    zabbix Agent: 6.0.1
    • 4996
    There seems to be one "cannot obtain configuration data from server" error also... maybe that's the reason... your proxy cannot get new config and is unaware that you have those hosts configured. When active agent turns to proxy, to get config, proxy answers "no, I don't know anything about you .. go away..."
    • shinmorpheus
      • Mar 2022
      • 9
      Hi Cyber,
      I've see this line this morning.
      I think that this problem is related to the 3 network interfaces present on this proxy, i need all 3 interface to monitor host in 3 differernt vlan (192.168.100., 192.168.200.x, 192.168.150.x).
      So all host reach correct the proxy.
      the server pin the proxy and the other way around also.
      The Server frontend show me the proxy active.
      any idea?
      thanks
        • 4996
        Which IP you used to define your proxy in GUI? Maybe you should put all those there, so server will accept proxy requests from all those IP-s?
        Why... Your proxy says, it cannot connect to server, so there is issue either with proxy config or network between proxy and server....
