Zabbix 5.4 to 6.x Upgrade Failure
  • mrosu
    • Jan 2022
    • 15
    I was not able to upgrade from 5.4 to 6.x due to some error/crash.
    I did stop zabbix server prior to upgrading.
    823:20220307:124226.335 Zabbix Server stopped. Zabbix 5.4.11 (revision 9aa30c495c).
    6533:20220307:124437.550 Starting Zabbix Server. Zabbix 6.0.1 (revision a80cb13868).
    6533:20220307:124437.550 ****** Enabled features ******
    6533:20220307:124437.550 SNMP monitoring: YES
    6533:20220307:124437.550 IPMI monitoring: YES
    6533:20220307:124437.550 Web monitoring: YES
    6533:20220307:124437.550 VMware monitoring: YES
    6533:20220307:124437.550 SMTP authentication: YES
    6533:20220307:124437.550 ODBC: YES
    6533:20220307:124437.550 SSH support: YES
    6533:20220307:124437.550 IPv6 support: YES
    6533:20220307:124437.550 TLS support: YES
    6533:20220307:124437.551 ******************************
    6533:20220307:124437.551 using configuration file: /etc/zabbix/zabbix_server.conf
    6533:20220307:124437.626 TimescaleDB version: 20501
    6533:20220307:124437.649 current database version (mandatory/optional): 05040000/05040001
    6533:20220307:124437.649 required mandatory version: 06000000
    6533:20220307:124437.649 starting automatic database upgrade
    6533:20220307:124437.749 completed 0% of database upgrade
    6533:20220307:124437.780 completed 1% of database upgrade
    <<<REMOVED TO REDUCE CHAR LIMIT ON POST>>>>>
    6533:20220307:124438.948 completed 100% of database upgrade
    6533:20220307:124438.948 database upgrade fully completed
    6533:20220307:124438.990 database could be upgraded to use primary keys in history tables
    6546:20220307:124439.056 starting HA manager
    6546:20220307:124439.094 HA manager started in active mode
    6533:20220307:124439.097 server #0 started [main process]
    6551:20220307:124439.099 server #1 started [service manager #1]
    6552:20220307:124439.100 server #2 started [configuration syncer #1]
    6552:20220307:124439.989 Got signal [signal:11(SIGSEGV),reason:2,refaddr:0x7f48ff8f540b]. Crashing ...
    6552:20220307:124439.989 ====== Fatal information: ======
    6552:20220307:124439.989 Program counter: 0x5636e27503f9
    6552:20220307:124439.989 === Registers: ===
    6552:20220307:124439.989 r8 = 17100 = 94464 = 94464
    6552:20220307:124439.989 r9 = 10 = 16 = 16
    6552:20220307:124439.990 r10 = 7f = 127 = 127
    6552:20220307:124439.990 r11 = 5636e5541040 = 94793775714368 = 94793775714368
    6552:20220307:124439.990 r12 = 5636e28af9f4 = 94793728981492 = 94793728981492
    6552:20220307:124439.990 r13 = 1 = 1 = 1
    6552:20220307:124439.990 r14 = 0 = 0 = 0
    6552:20220307:124439.990 r15 = 0 = 0 = 0
    6552:20220307:124439.990 rdi = 7f48ff8f540b = 139951501956107 = 139951501956107
    6552:20220307:124439.990 rsi = 7fff43dde80eb36c = 9223165182238176108 = 9223165182238176108
    6552:20220307:124439.990 rbp = 7fff64b3f920 = 140734882904352 = 140734882904352
    6552:20220307:124439.990 rbx = 2 = 2 = 2
    6552:20220307:124439.990 rdx = 7fff43dde80eb36c = 9223165182238176108 = 9223165182238176108
    6552:20220307:124439.990 rax = 7f48ff8f540b = 139951501956107 = 139951501956107
    6552:20220307:124439.990 rcx = 7f48ff8de303 = 139951501861635 = 139951501861635
    6552:20220307:124439.990 rsp = 7fff64b3f920 = 140734882904352 = 140734882904352
    6552:20220307:124439.990 rip = 5636e27503f9 = 94793727542265 = 94793727542265
    6552:20220307:124439.990 efl = 10206 = 66054 = 66054
    6552:20220307:124439.990 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
    6552:20220307:124439.991 err = 7 = 7 = 7
    6552:20220307:124439.991 trapno = e = 14 = 14
    6552:20220307:124439.991 oldmask = 0 = 0 = 0
    6552:20220307:124439.991 cr2 = 7f48ff8f540b = 139951501956107 = 139951501956107
    6552:20220307:124439.991 === Backtrace: ===
    6552:20220307:124439.993 18: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x3f) [0x5636e2756755]
    6552:20220307:124439.993 17: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_log_fatal_info+0x141) [0x5636e27569b3]
    6552:20220307:124439.993 16: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x24f1df) [0x5636e27571df]
    6552:20220307:124439.993 15: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14140) [0x7f48ff5b6140]
    6552:20220307:124439.993 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x2483f9) [0x5636e27503f9]
    6552:20220307:124439.993 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x248b46) [0x5636e2750b46]
    6552:20220307:124439.993 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_realloc+0xad) [0x5636e2751974]
    6552:20220307:124439.994 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1d2b81) [0x5636e26dab81]
    6552:20220307:124439.994 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1e0456) [0x5636e26e8456]
    6552:20220307:124439.994 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1e0958) [0x5636e26e8958]
    6552:20220307:124439.994 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0x161b) [0x5636e26ea1f6]
    6552:20220307:124439.994 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x136) [0x5636e25808ad]
    6552:20220307:124439.994 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x5636e2766bcc]
    6552:20220307:124439.994 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x66969) [0x5636e256e969]
    6552:20220307:124439.994 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x7b8) [0x5636e256fb3e]
    6552:20220307:124439.994 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2f5) [0x5636e2756358]
    6552:20220307:124439.994 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x339) [0x5636e256e08b]
    6552:20220307:124439.994 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea) [0x7f48feb73d0a]
    6552:20220307:124439.994 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2a) [0x5636e256cdba]
    6552:20220307:124439.994 === Memory map: ===
    6552:20220307:124439.994 5636e2508000-5636e256b000 r--p 00000000 fe:01 1181112 /usr/sbin/zabbix_server
    6552:20220307:124439.994 5636e256b000-5636e2863000 r-xp 00063000 fe:01 1181112 /usr/sbin/zabbix_server
    6552:20220307:124439.995 5636e2863000-5636e2982000 r--p 0035b000 fe:01 1181112 /usr/sbin/zabbix_server
    6552:20220307:124439.995 5636e2983000-5636e2a4c000 r--p 0047a000 fe:01 1181112 /usr/sbin/zabbix_server
    6552:20220307:124439.995 5636e2a4c000-5636e2a5c000 rw-p 00543000 fe:01 1181112 /usr/sbin/zabbix_server
    6552:20220307:124439.995 5636e2a5c000-5636e2a6b000 rw-p 00000000 00:00 0
    6552:20220307:124439.995 5636e4264000-5636e42a6000 rw-p 00000000 00:00 0 [heap]
    6552:20220307:124439.995 5636e42a6000-5636e42e8000 rw-p 00000000 00:00 0 [heap]
    6552:20220307:124439.995 5636e42e8000-5636e557d000 rw-p 00000000 00:00 0 [heap]
    6552:20220307:124439.995 7f47f4217000-7f47f4617000 rw-s 00000000 00:01 16 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f47f4617000-7f47faa17000 rw-s 00000000 00:01 15 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f47faa17000-7f48faa17000 rw-s 00000000 00:01 13 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f48faa17000-7f48fae17000 rw-s 00000000 00:01 12 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f48fae17000-7f48fb217000 rw-s 00000000 00:01 11 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f48fb217000-7f48fc217000 rw-s 00000000 00:01 10 /SYSV00000000 (deleted)
    6552:20220307:124439.995 7f48fc217000-7f48fc21d000 r--p 00000000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.995 7f48fc21d000-7f48fc242000 r-xp 00006000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.996 7f48fc242000-7f48fc24d000 r--p 0002b000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.996 7f48fc24d000-7f48fc24e000 ---p 00036000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.996 7f48fc24e000-7f48fc251000 r--p 00036000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.996 7f48fc251000-7f48fc252000 rw-p 00039000 fe:01 1182736 /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    6552:20220307:124439.996 7f48fc252000-7f48fc255000 r--p 00000000 fe:01 2753081 /lib/x86_64-linux-gnu/libnss_files-2.31.so
    6552:20220307:124439.996 7f48fc255000-7f48fc25c000 r-xp 00003000 fe:01 2753081 /lib/x86_64-linux-gnu/libnss_files-2.31.so
    6552:20220307:124439.996 7f48fc25c000-7f48fc25e000 r--p 0000a000 fe:01 2753081 /lib/x86_64-linux-gnu/libnss_files-2.31.so
    6552:20220307:124439.996 7f48fc25e000-7f48fc25f000 r--p 0000b000 fe:01 2753081 /lib/x86_64-linux-gnu/libnss_files-2.31.so
    6552:20220307:124439.996 7f48fc25f000-7f48fc260000 rw-p 0000c000 fe:01 2753081 /lib/x86_64-linux-gnu/libnss_files-2.31.so
    6552:20220307:124439.996 7f48fc260000-7f48fc26d000 rw-p 00000000 00:00 0
    6552:20220307:124439.996 7f48fc26d000-7f48fc271000 r--p 00000000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc271000-7f48fc286000 r-xp 00004000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc286000-7f48fc290000 r--p 00019000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc290000-7f48fc291000 ---p 00023000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc291000-7f48fc292000 r--p 00023000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc292000-7f48fc293000 rw-p 00024000 fe:01 2754866 /lib/x86_64-linux-gnu/libgpg-error.so.0.29.0
    6552:20220307:124439.996 7f48fc293000-7f48fc295000 rw-p 00000000 00:00 0
    6552:20220307:124439.996 7f48fc295000-7f48fc297000 r--p 00000000 fe:01 1182909 /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    6552:20220307:124439.996 7f48fc297000-7f48fc29d000 r-xp 00002000 fe:01 1182909 /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    6552:20220307:124439.996 7f48fc29d000-7f48fc29f000 r--p 00008000 fe:01 1182909 /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    6552:20220307:124439.997 7f48fc29f000-7f48fc2a0000 r--p 00009000 fe:01 1182909 /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    6552:20220307:124439.997 7f48fc2a0000-7f48fc2a1000 rw-p 0000a000 fe:01 1182909 /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    6552:20220307:124439.997 7f48fc2a1000-7f48fc2a3000 r--p 00000000 fe:01 2752568 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
    6552:20220307:124439.997 7f48fc2a3000-7f48fc2a5000 r-xp 00002000 fe:01 2752568 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
    6552:20220307:124439.997 7f48fc2a5000-7f48fc2a6000 r--p 00004000 fe:01 2752568 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
    6552:20220307:124439.997 7f48fc2a6000-7f48fc2a7000 r--p 00004000 fe:01 2752568 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
    6552:20220307:124439.997 7f48fc2a7000-7f48fc2a8000 rw-p 00005000 fe:01 2752568 /lib/x86_64-linux-gnu/libkeyutils.so.1.9
    6552:20220307:124439.997 7f48fc2a8000-7f48fc2ab000 r--p 00000000 fe:01 2752562 /lib/x86_64-linux-gnu/libgcc_s.so.1
    6552:20220307:124439.997 7f48fc2ab000-7f48fc2bc000 r-xp 00003000 fe:01 2752562 /lib/x86_64-linux-gnu/libgcc_s.so.1
    6552:20220307:124439.997 7f48fc2bc000-7f48fc2c0000 r--p 00014000 fe:01 2752562 /lib/x86_64-linux-gnu/libgcc_s.so.1
    6552:20220307:124439.997 7f48fc2c0000-7f48fc2c1000 r--p 00017000 fe:01 2752562 /lib/x86_64-linux-gnu/libgcc_s.so.1
    6552:20220307:124439.997 7f48fc2c1000-7f48fc2c2000 rw-p 00018000 fe:01 2752562 /lib/x86_64-linux-gnu/libgcc_s.so.1
    6552:20220307:124439.997 7f48fc2c2000-7f48fc358000 r--p 00000000 fe:01 1181559 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    6552:20220307:124439.997 7f48fc358000-7f48fc434000 r-xp 00096000 fe:01 1181559 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    6552:20220307:124439.997 7f48fc434000-7f48fc47e000 r--p 00172000 fe:01 1181559 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    6552:20220307:124439.997 7f48fc47e000-7f48fc489000 r--p 001bb000 fe:01 1181559 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    6552:20220307:124439.997 7f48fc489000-7f48fc48c000 rw-p 001c6000 fe:01 1181559 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    6552:20220307:124439.997 7f48fc48c000-7f48fc48f000 rw-p 00000000 00:00 0
    6552:20220307:124439.997 7f48fc48f000-7f48fc490000 r--p 00000000 fe:01 1183680 /usr/lib/x86_64-linux-gnu/libicudata.so.67.1
    6552:20220307:124439.997 7f48fc490000-7f48fc491000 r-xp 00001000 fe:01 1183680 /usr/lib/x86_64-linux-gnu/libicudata.so.67.1
    6552:20220307:124439.997 7f48fc491000-7f48fdfa6000 r--p 00002000 fe:01 1183680 /usr/lib/x86_64-linux-gnu/libicudata.so.67.1
    6552:20220307:124439.997 7f48fdfa6000-7f48fdfa7000 r--p 01b16000 fe:01 1183680 /usr/lib/x86_64-linux-gnu/libicudata.so.67.1
    6552:20220307:124439.997 7f48fdfa7000-7f48fdfa8000 rw-p 01b17000 fe:01 1183680 /usr/lib/x86_64-linux-gnu/libicudata.so.67.1
    6552:20220307:124439.997 7f48fdfa8000-7f48fdfaa000 rw-p 00000000 00:00 0
    6552:20220307:124439.997 7f48fdfaa000-7f48fdfab000 r--p 00000000 fe:01 1180831 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    6552:20220307:124439.997 7f48fdfab000-7f48fdfac000 r-xp 00001000 fe:01 1180831 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    6552:20220307:124439.997 7f48fdfac000-7f48fdfcb000 r--p 00002000 fe:01 1180831 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    6552:20220307:124439.997 7f48fdfcb000-7f48fdfcc000 r--p 00020000 fe:01 1180831 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    6552:20220307:124439.998 7f48fdfcc000-7f48fdfcd000 rw-p 00021000 fe:01 1180831 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.9
    6552:20220307:124439.998 7f48fdfcd000-7f48fdfd9000 r--p 00000000 fe:01 1181524 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.2.8
    6552:20220307:124439.998 7f48fdfd9000-7f48fe0a9000 r-xp 0000c000 fe:01 1181524 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.2.8
    6552:20220307:124439.998 7f48fe0a9000-7f48fe0e6000 r--p 000dc000 fe:01 1181524 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.2.8
    6552:20220307:124439.998 7f48fe0e6000-7f48fe0e8000 r--p 00118000 fe:01 1181524 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.2.8
    6552:20220307:124439.998 7f48fe0e8000-7f48fe0ed000 rw-p 0011a000 fe:01 1181524 /usr/lib/x86_64-linux-gnu/libgcrypt.so.20.2.8
    6552:20220307:124439.998 7f48fe0ed000-7f48fe0f8000 r--p 00000000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe0f8000-7f48fe154000 r-xp 0000b000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe154000-7f48fe16b000 r--p 00067000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe16b000-7f48fe16c000 ---p 0007e000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe16c000-7f48fe16d000 r--p 0007e000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe16d000-7f48fe16e000 rw-p 0007f000 fe:01 1180290 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.1
    6552:20220307:124439.998 7f48fe16e000-7f48fe177000 r--p 00000000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe177000-7f48fe18a000 r-xp 00009000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe18a000-7f48fe1b4000 r--p 0001c000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe1b4000-7f48fe1b5000 ---p 00046000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe1b5000-7f48fe1b6000 r--p 00046000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe1b6000-7f48fe1b7000 rw-p 00047000 fe:01 1181800 /usr/lib/x86_64-linux-gnu/libhogweed.so.6.4
    6552:20220307:124439.998 7f48fe1b7000-7f48fe1c3000 r--p 00000000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1c3000-7f48fe1e5000 r-xp 0000c000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1e5000-7f48fe1fb000 r--p 0002e000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1fb000-7f48fe1fc000 ---p 00044000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1fc000-7f48fe1fe000 r--p 00044000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1fe000-7f48fe1ff000 rw-p 00046000 fe:01 1181794 /usr/lib/x86_64-linux-gnu/libnettle.so.8.4
    6552:20220307:124439.998 7f48fe1ff000-7f48fe201000 rw-p 00000000 00:00 0
    6552:20220307:124439.998 7f48fe201000-7f48fe204000 r--p 00000000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.998 7f48fe204000-7f48fe210000 r-xp 00003000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.998 7f48fe210000-7f48fe214000 r--p 0000f000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.998 7f48fe214000-7f48fe215000 ---p 00013000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.998 7f48fe215000-7f48fe216000 r--p 00013000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.999 7f48fe216000-7f48fe217000 rw-p 00014000 fe:01 1180625 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    6552:20220307:124439.999 7f48fe217000-7f48fe228000 r--p 00000000 fe:01 1180424 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    6552:20220307:124439.999 7f48fe228000-7f48fe25d000 r-xp 00011000 fe:01 1180424 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    6552:20220307:124439.999 7f48fe25d000-7f48fe394000 r--p 00046000 fe:01 1180424 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    6552:20220307:124439.999 7f48fe394000-7f48fe398000 r--p 0017c000 fe:01 1180424 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    6552:20220307:124439.999 7f48fe398000-7f48fe399000 rw-p 00180000 fe:01 1180424 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    6552:20220307:124439.999 7f48fe399000-7f48fe3c4000 r--p 00000000 fe:01 1188756 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    6552:20220307:124439.999 7f48fe3c4000-7f48fe45c000 r-xp 0002b000 fe:01 1188756 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    6552:20220307:124439.999 7f48fe45c000-7f48fe4b8000 r--p 000c3000 fe:01 1188756 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    6552:20220307:124439.999 7f48fe4b8000-7f48fe4c3000 r--p 0011e000 fe:01 1188756 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    6552:20220307:124439.999 7f48fe4c3000-7f48fe4cd000 rw-p 00129000 fe:01 1188756 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    6552:20220307:124439.999 7f48fe4cd000-7f48fe4d0000 r--p 00000000 fe:01 1182844 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    6552:20220307:124439.999 7f48fe4d0000-7f48fe4d7000 r-xp 00003000 fe:01 1182844 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    6552:20220307:124439.999 7f48fe4d7000-7f48fe4da000 r--p 0000a000 fe:01 1182844 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    6552:20220307:124439.999 7f48fe4da000-7f48fe4db000 r--p 0000c000 fe:01 1182844 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    6552:20220307:124439.999 7f48fe4db000-7f48fe4dc000 rw-p 0000d000 fe:01 1182844 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    6552:20220307:124439.999 7f48fe4dc000-7f48fe4de000 r--p 00000000 fe:01 2752980 /lib/x86_64-linux-gnu/libcom_err.so.2.1
    6552:20220307:124439.999 7f48fe4de000-7f48fe4df000 r-xp 00002000 fe:01 2752980 /lib/x86_64-linux-gnu/libcom_err.so.2.1
    6552:20220307:124439.999 7f48fe4df000-7f48fe4e0000 r--p 00003000 fe:01 2752980 /lib/x86_64-linux-gnu/libcom_err.so.2.1
    6552:20220307:124439.999 7f48fe4e0000-7f48fe4e1000 r--p 00003000 fe:01 2752980 /lib/x86_64-linux-gnu/libcom_err.so.2.1
    6552:20220307:124439.999 7f48fe4e1000-7f48fe4e2000 rw-p 00004000 fe:01 2752980 /lib/x86_64-linux-gnu/libcom_err.so.2.1
    6552:20220307:124439.999 7f48fe4e2000-7f48fe4e6000 r--p 00000000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124439.999 7f48fe4e6000-7f48fe501000 r-xp 00004000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124439.999 7f48fe501000-7f48fe50e000 r--p 0001f000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124439.999 7f48fe50e000-7f48fe50f000 ---p 0002c000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124439.999 7f48fe50f000-7f48fe510000 r--p 0002c000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124439.999 7f48fe510000-7f48fe511000 rw-p 0002d000 fe:01 1180429 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    6552:20220307:124440.000 7f48fe511000-7f48fe514000 rw-p 00000000 00:00 0
    6552:20220307:124440.000 7f48fe514000-7f48fe537000 r--p 00000000 fe:01 1180654 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    6552:20220307:124440.000 7f48fe537000-7f48fe595000 r-xp 00023000 fe:01 1180654 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    6552:20220307:124440.000 7f48fe595000-7f48fe5dd000 r--p 00081000 fe:01 1180654 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    6552:20220307:124440.000 7f48fe5dd000-7f48fe5eb000 r--p 000c8000 fe:01 1180654 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    6552:20220307:124440.000 7f48fe5eb000-7f48fe5ee000 rw-p 000d6000 fe:01 1180654 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    6552:20220307:124440.000 7f48fe5ee000-7f48fe5f1000 r--p 00000000 fe:01 2752591 /lib/x86_64-linux-gnu/liblzma.so.5.2.5
    6552:20220307:124440.000 7f48fe5f1000-7f48fe609000 r-xp 00003000 fe:01 2752591 /lib/x86_64-linux-gnu/liblzma.so.5.2.5
    6552:20220307:124440.000 7f48fe609000-7f48fe614000 r--p 0001b000 fe:01 2752591 /lib/x86_64-linux-gnu/liblzma.so.5.2.5
    6552:20220307:124440.000 7f48fe614000-7f48fe615000 r--p 00025000 fe:01 2752591 /lib/x86_64-linux-gnu/liblzma.so.5.2.5
    6552:20220307:124440.000 7f48fe615000-7f48fe616000 rw-p 00026000 fe:01 2752591 /lib/x86_64-linux-gnu/liblzma.so.5.2.5
    6552:20220307:124440.000 7f48fe616000-7f48fe67c000 r--p 00000000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe67c000-7f48fe762000 r-xp 00066000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe762000-7f48fe7e9000 r--p 0014c000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe7e9000-7f48fe7ea000 ---p 001d3000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe7ea000-7f48fe7fc000 r--p 001d3000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe7fc000-7f48fe7fd000 rw-p 001e5000 fe:01 1183685 /usr/lib/x86_64-linux-gnu/libicuuc.so.67.1
    6552:20220307:124440.000 7f48fe7fd000-7f48fe7ff000 rw-p 00000000 00:00 0
    6552:20220307:124440.000 7f48fe7ff000-7f48fe800000 r--p 00000000 fe:01 1180832 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    6552:20220307:124440.000 7f48fe800000-7f48fe808000 r-xp 00001000 fe:01 1180832 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    6552:20220307:124440.000 7f48fe808000-7f48fe80b000 r--p 00009000 fe:01 1180832 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    6552:20220307:124440.000 7f48fe80b000-7f48fe80c000 r--p 0000b000 fe:01 1180832 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    6552:20220307:124440.000 7f48fe80c000-7f48fe80d000 rw-p 0000c000 fe:01 1180832 /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.9
    6552:20220307:124440.000 7f48fe80d000-7f48fe80f000 r--p 00000000 fe:01 1180561 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    6552:20220307:124440.000 7f48fe80f000-7f48fe811000 r-xp 00002000 fe:01 1180561 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    6552:20220307:124440.000 7f48fe811000-7f48fe81f000 r--p 00004000 fe:01 1180561 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    6552:20220307:124440.000 7f48fe81f000-7f48fe820000 r--p 00011000 fe:01 1180561 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    6552:20220307:124440.000 7f48fe820000-7f48fe821000 rw-p 00012000 fe:01 1180561 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    6552:20220307:124440.001 7f48fe821000-7f48fe823000 rw-p 00000000 00:00 0
    6552:20220307:124440.001 7f48fe823000-7f48fe828000 r--p 00000000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe828000-7f48fe84a000 r-xp 00005000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe84a000-7f48fe855000 r--p 00027000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe855000-7f48fe856000 ---p 00032000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe856000-7f48fe857000 r--p 00032000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe857000-7f48fe858000 rw-p 00033000 fe:01 1180613 /usr/lib/x86_64-linux-gnu/libssh2.so.1.0.1
    6552:20220307:124440.001 7f48fe858000-7f48fe85d000 r--p 00000000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe85d000-7f48fe86d000 r-xp 00005000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe86d000-7f48fe874000 r--p 00015000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe874000-7f48fe875000 ---p 0001c000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe875000-7f48fe876000 r--p 0001c000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe876000-7f48fe877000 rw-p 0001d000 fe:01 1180866 /usr/lib/x86_64-linux-gnu/librtmp.so.1
    6552:20220307:124440.001 7f48fe877000-7f48fe879000 r--p 00000000 fe:01 1181690 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    6552:20220307:124440.001 7f48fe879000-7f48fe87d000 r-xp 00002000 fe:01 1181690 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    6552:20220307:124440.001 7f48fe87d000-7f48fe896000 r--p 00006000 fe:01 1181690 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    6552:20220307:124440.001 7f48fe896000-7f48fe897000 r--p 0001e000 fe:01 1181690 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    6552:20220307:124440.001 7f48fe897000-7f48fe898000 rw-p 0001f000 fe:01 1181690 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.7
    6552:20220307:124440.001 7f48fe898000-7f48fe89d000 r--p 00000000 fe:01 1180860 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    6552:20220307:124440.001 7f48fe89d000-7f48fe8b3000 r-xp 00005000 fe:01 1180860 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    6552:20220307:124440.001 7f48fe8b3000-7f48fe8c1000 r--p 0001b000 fe:01 1180860 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    6552:20220307:124440.001 7f48fe8c1000-7f48fe8c4000 r--p 00028000 fe:01 1180860 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    6552:20220307:124440.001 7f48fe8c4000-7f48fe8c5000 rw-p 0002b000 fe:01 1180860 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.20.1
    6552:20220307:124440.001 7f48fe8c5000-7f48fe8f9000 r--p 00000000 fe:01 1181314 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.29.1
    6552:20220307:124440.001 7f48fe8f9000-7f48fea1a000 r-xp 00034000 fe:01 1181314 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.29.1
    6552:20220307:124440.001 7f48fea1a000-7f48feab0000 r--p 00155000 fe:01 1181314 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.29.1
    6552:20220307:124440.001 7f48feab0000-7f48feac1000 r--p 001ea000 fe:01 1181314 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.29.1
    6552:20220307:124440.001 7f48feac1000-7f48feac3000 rw-p 001fb000 fe:01 1181314 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.29.1
    6552:20220307:124440.001 7f48feac3000-7f48feac5000 rw-p 00000000 00:00 0
    6552:20220307:124440.001 7f48feac5000-7f48feac8000 r--p 00000000 fe:01 1182976 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    6552:20220307:124440.002 7f48feac8000-7f48feada000 r-xp 00003000 fe:01 1182976 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    6552:20220307:124440.002 7f48feada000-7f48feae0000 r--p 00015000 fe:01 1182976 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    6552:20220307:124440.002 7f48feae0000-7f48feae1000 r--p 0001a000 fe:01 1182976 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    6552:20220307:124440.002 7f48feae1000-7f48feae2000 rw-p 0001b000 fe:01 1182976 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    6552:20220307:124440.002 7f48feae2000-7f48feae4000 rw-p 00000000 00:00 0
    6552:20220307:124440.002 7f48feae4000-7f48feae6000 r--p 00000000 fe:01 1185307 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    6552:20220307:124440.002 7f48feae6000-7f48feaeb000 r-xp 00002000 fe:01 1185307 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    6552:20220307:124440.002 7f48feaeb000-7f48feaed000 r--p 00007000 fe:01 1185307 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    6552:20220307:124440.002 7f48feaed000-7f48feaee000 r--p 00008000 fe:01 1185307 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    6552:20220307:124440.002 7f48feaee000-7f48feaef000 rw-p 00009000 fe:01 1185307 /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    6552:20220307:124440.002 7f48feaef000-7f48feaf1000 r--p 00000000 fe:01 1183145 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    6552:20220307:124440.002 7f48feaf1000-7f48feaf6000 r-xp 00002000 fe:01 1183145 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    6552:20220307:124440.002 7f48feaf6000-7f48feaf8000 r--p 00007000 fe:01 1183145 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    6552:20220307:124440.002 7f48feaf8000-7f48feaf9000 r--p 00008000 fe:01 1183145 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    6552:20220307:124440.002 7f48feaf9000-7f48feafa000 rw-p 00009000 fe:01 1183145 /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    6552:20220307:124440.002 7f48feafa000-7f48feb06000 r--p 00000000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb06000-7f48feb3b000 r-xp 0000c000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb3b000-7f48feb48000 r--p 00041000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb48000-7f48feb49000 ---p 0004e000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb49000-7f48feb4b000 r--p 0004e000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb4b000-7f48feb4d000 rw-p 00050000 fe:01 1179861 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    6552:20220307:124440.002 7f48feb4d000-7f48feb72000 r--p 00000000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.002 7f48feb72000-7f48fecbd000 r-xp 00025000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.003 7f48fecbd000-7f48fed07000 r--p 00170000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.003 7f48fed07000-7f48fed08000 ---p 001ba000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.003 7f48fed08000-7f48fed0b000 r--p 001ba000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.003 7f48fed0b000-7f48fed0e000 rw-p 001bd000 fe:01 2753072 /lib/x86_64-linux-gnu/libc-2.31.so
    6552:20220307:124440.003 7f48fed0e000-7f48fed12000 rw-p 00000000 00:00 0
    6552:20220307:124440.003 7f48fed12000-7f48fed14000 r--p 00000000 fe:01 1181361 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.1
    6552:20220307:124440.003 7f48fed14000-7f48fed7f000 r-xp 00002000 fe:01 1181361 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.1
    6552:20220307:124440.003 7f48fed7f000-7f48feda8000 r--p 0006d000 fe:01 1181361 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.1
    6552:20220307:124440.003 7f48feda8000-7f48feda9000 r--p 00095000 fe:01 1181361 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.1
    6552:20220307:124440.003 7f48feda9000-7f48fedaa000 rw-p 00096000 fe:01 1181361 /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.10.1
    6552:20220307:124440.003 7f48fedaa000-7f48fedac000 rw-p 00000000 00:00 0
    6552:20220307:124440.003 7f48fedac000-7f48fedda000 r--p 00000000 fe:01 1183693 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    6552:20220307:124440.003 7f48fedda000-7f48feef6000 r-xp 0002e000 fe:01 1183693 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    6552:20220307:124440.003 7f48feef6000-7f48fef4e000 r--p 0014a000 fe:01 1183693 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    6552:20220307:124440.003 7f48fef4e000-7f48fef57000 r--p 001a1000 fe:01 1183693 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    6552:20220307:124440.003 7f48fef57000-7f48fef58000 rw-p 001aa000 fe:01 1183693 /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    6552:20220307:124440.003 7f48fef58000-7f48fef5a000 rw-p 00000000 00:00 0
    6552:20220307:124440.003 7f48fef5a000-7f48fef5e000 r--p 00000000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef5e000-7f48fef6c000 r-xp 00004000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef6c000-7f48fef6f000 r--p 00012000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef6f000-7f48fef70000 ---p 00015000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef70000-7f48fef71000 r--p 00015000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef71000-7f48fef72000 rw-p 00016000 fe:01 2753085 /lib/x86_64-linux-gnu/libresolv-2.31.so
    6552:20220307:124440.003 7f48fef72000-7f48fef74000 rw-p 00000000 00:00 0
    6552:20220307:124440.003 7f48fef74000-7f48fef75000 r--p 00000000 fe:01 2753073 /lib/x86_64-linux-gnu/libdl-2.31.so
    6552:20220307:124440.003 7f48fef75000-7f48fef77000 r-xp 00001000 fe:01 2753073 /lib/x86_64-linux-gnu/libdl-2.31.so
    6552:20220307:124440.003 7f48fef77000-7f48fef78000 r--p 00003000 fe:01 2753073 /lib/x86_64-linux-gnu/libdl-2.31.so
    6552:20220307:124440.004 7f48fef78000-7f48fef79000 r--p 00003000 fe:01 2753073 /lib/x86_64-linux-gnu/libdl-2.31.so
    6552:20220307:124440.004 7f48fef79000-7f48fef7a000 rw-p 00004000 fe:01 2753073 /lib/x86_64-linux-gnu/libdl-2.31.so
    6552:20220307:124440.004 7f48fef7a000-7f48fef89000 r--p 00000000 fe:01 2753074 /lib/x86_64-linux-gnu/libm-2.31.so
    6552:20220307:124440.004 7f48fef89000-7f48ff023000 r-xp 0000f000 fe:01 2753074 /lib/x86_64-linux-gnu/libm-2.31.so
    6552:20220307:124440.004 7f48ff023000-7f48ff0bc000 r--p 000a9000 fe:01 2753074 /lib/x86_64-linux-gnu/libm-2.31.so
    6552:20220307:124440.004 7f48ff0bc000-7f48ff0bd000 r--p 00141000 fe:01 2753074 /lib/x86_64-linux-gnu/libm-2.31.so
    6552:20220307:124440.004 7f48ff0bd000-7f48ff0be000 rw-p 00142000 fe:01 2753074 /lib/x86_64-linux-gnu/libm-2.31.so
    6552:20220307:124440.004 7f48ff0be000-7f48ff0cd000 r--p 00000000 fe:01 1183493 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    6552:20220307:124440.004 7f48ff0cd000-7f48ff135000 r-xp 0000f000 fe:01 1183493 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    6552:20220307:124440.004 7f48ff135000-7f48ff152000 r--p 00077000 fe:01 1183493 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    6552:20220307:124440.004 7f48ff152000-7f48ff156000 r--p 00093000 fe:01 1183493 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    6552:20220307:124440.004 7f48ff156000-7f48ff158000 rw-p 00097000 fe:01 1183493 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
    6552:20220307:124440.004 7f48ff158000-7f48ff159000 rw-p 00000000 00:00 0
    6552:20220307:124440.004 7f48ff159000-7f48ff15c000 r--p 00000000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff15c000-7f48ff164000 r-xp 00003000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff164000-7f48ff167000 r--p 0000b000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff167000-7f48ff168000 ---p 0000e000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff168000-7f48ff169000 r--p 0000e000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff169000-7f48ff16a000 rw-p 0000f000 fe:01 1181518 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff16a000-7f48ff16c000 rw-p 00000000 00:00 0
    6552:20220307:124440.004 7f48ff16c000-7f48ff17a000 r--p 00000000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff17a000-7f48ff1ad000 r-xp 0000e000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff1ad000-7f48ff1bc000 r--p 00041000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff1bc000-7f48ff1bd000 ---p 00050000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff1bd000-7f48ff1bf000 r--p 00050000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff1bf000-7f48ff1c0000 rw-p 00052000 fe:01 1182253 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.11.5
    6552:20220307:124440.004 7f48ff1c0000-7f48ff1c2000 rw-p 00000000 00:00 0
    6552:20220307:124440.004 7f48ff1c2000-7f48ff248000 r--p 00000000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.004 7f48ff248000-7f48ff3ef000 r-xp 00086000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.005 7f48ff3ef000-7f48ff47f000 r--p 0022d000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.005 7f48ff47f000-7f48ff480000 ---p 002bd000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.005 7f48ff480000-7f48ff4b0000 r--p 002bd000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.005 7f48ff4b0000-7f48ff4b2000 rw-p 002ed000 fe:01 1183712 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    6552:20220307:124440.005 7f48ff4b2000-7f48ff4b6000 rw-p 00000000 00:00 0
    6552:20220307:124440.005 7f48ff4b6000-7f48ff4d3000 r--p 00000000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff4d3000-7f48ff521000 r-xp 0001d000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff521000-7f48ff53b000 r--p 0006b000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff53b000-7f48ff53c000 ---p 00085000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff53c000-7f48ff545000 r--p 00085000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff545000-7f48ff549000 rw-p 0008e000 fe:01 1184271 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    6552:20220307:124440.005 7f48ff549000-7f48ff557000 r--p 00000000 fe:01 1180907 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    6552:20220307:124440.005 7f48ff557000-7f48ff58b000 r-xp 0000e000 fe:01 1180907 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    6552:20220307:124440.005 7f48ff58b000-7f48ff59f000 r--p 00042000 fe:01 1180907 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    6552:20220307:124440.005 7f48ff59f000-7f48ff5a1000 r--p 00055000 fe:01 1180907 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    6552:20220307:124440.005 7f48ff5a1000-7f48ff5a2000 rw-p 00057000 fe:01 1180907 /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.1
    6552:20220307:124440.005 7f48ff5a2000-7f48ff5a9000 r--p 00000000 fe:01 2753084 /lib/x86_64-linux-gnu/libpthread-2.31.so
    6552:20220307:124440.005 7f48ff5a9000-7f48ff5b9000 r-xp 00007000 fe:01 2753084 /lib/x86_64-linux-gnu/libpthread-2.31.so
    6552:20220307:124440.005 7f48ff5b9000-7f48ff5be000 r--p 00017000 fe:01 2753084 /lib/x86_64-linux-gnu/libpthread-2.31.so
    6552:20220307:124440.005 7f48ff5be000-7f48ff5bf000 r--p 0001b000 fe:01 2753084 /lib/x86_64-linux-gnu/libpthread-2.31.so
    6552:20220307:124440.005 7f48ff5bf000-7f48ff5c0000 rw-p 0001c000 fe:01 2753084 /lib/x86_64-linux-gnu/libpthread-2.31.so
    6552:20220307:124440.005 7f48ff5c0000-7f48ff5c4000 rw-p 00000000 00:00 0
    6552:20220307:124440.005 7f48ff5c4000-7f48ff5c7000 r--p 00000000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5c7000-7f48ff5d8000 r-xp 00003000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5d8000-7f48ff5de000 r--p 00014000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5de000-7f48ff5df000 ---p 0001a000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5df000-7f48ff5e0000 r--p 0001a000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5e0000-7f48ff5e1000 rw-p 0001b000 fe:01 2752651 /lib/x86_64-linux-gnu/libz.so.1.2.11
    6552:20220307:124440.005 7f48ff5e1000-7f48ff5e3000 rw-p 00000000 00:00 0
    6552:20220307:124440.005 7f48ff5e3000-7f48ff5e5000 r--p 00000000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5e5000-7f48ff5e9000 r-xp 00002000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5e9000-7f48ff5ea000 r--p 00006000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5ea000-7f48ff5eb000 ---p 00007000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5eb000-7f48ff5ec000 r--p 00007000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5ec000-7f48ff5ed000 rw-p 00008000 fe:01 1185301 /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    6552:20220307:124440.006 7f48ff5ed000-7f48ff620000 r--p 00000000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff620000-7f48ff6a2000 r-xp 00033000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff6a2000-7f48ff6e1000 r--p 000b5000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff6e1000-7f48ff6e2000 ---p 000f4000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff6e2000-7f48ff6fa000 r--p 000f4000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff6fa000-7f48ff6ff000 rw-p 0010c000 fe:01 1185293 /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    6552:20220307:124440.006 7f48ff6ff000-7f48ff703000 rw-p 00000000 00:00 0
    6552:20220307:124440.006 7f48ff703000-7f48ff711000 r--p 00000000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff711000-7f48ff752000 r-xp 0000e000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff752000-7f48ff76d000 r--p 0004f000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff76d000-7f48ff76e000 ---p 0006a000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff76e000-7f48ff770000 r--p 0006a000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff770000-7f48ff772000 rw-p 0006c000 fe:01 1180356 /usr/lib/x86_64-linux-gnu/libssh.so.4.8.6
    6552:20220307:124440.006 7f48ff772000-7f48ff78e000 r--p 00000000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff78e000-7f48ff81b000 r-xp 0001c000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff81b000-7f48ff849000 r--p 000a9000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff849000-7f48ff84a000 ---p 000d7000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff84a000-7f48ff84d000 r--p 000d7000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff84d000-7f48ff850000 rw-p 000da000 fe:01 1186044 /usr/lib/x86_64-linux-gnu/libnetsnmp.so.40.0.0
    6552:20220307:124440.006 7f48ff850000-7f48ff855000 rw-p 00000000 00:00 0
    6552:20220307:124440.006 7f48ff855000-7f48ff85c000 r--p 00000000 fe:01 1185281 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    6552:20220307:124440.006 7f48ff85c000-7f48ff8aa000 r-xp 00007000 fe:01 1185281 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    6552:20220307:124440.007 7f48ff8aa000-7f48ff8bb000 r--p 00055000 fe:01 1185281 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    6552:20220307:124440.007 7f48ff8bb000-7f48ff8bc000 r--p 00065000 fe:01 1185281 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    6552:20220307:124440.007 7f48ff8bc000-7f48ff8c3000 rw-p 00066000 fe:01 1185281 /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    6552:20220307:124440.007 7f48ff8c3000-7f48ff8c7000 rw-p 00000000 00:00 0
    6552:20220307:124440.007 7f48ff8c7000-7f48ff8d2000 r--p 00000000 fe:01 1184179 /usr/lib/x86_64-linux-gnu/libpq.so.5.14
    6552:20220307:124440.007 7f48ff8d2000-7f48ff8f6000 r-xp 0000b000 fe:01 1184179 /usr/lib/x86_64-linux-gnu/libpq.so.5.14
    6552:20220307:124440.007 7f48ff8f6000-7f48ff915000 r--p 0002f000 fe:01 1184179 /usr/lib/x86_64-linux-gnu/libpq.so.5.14
    6552:20220307:124440.007 7f48ff915000-7f48ff919000 r--p 0004d000 fe:01 1184179 /usr/lib/x86_64-linux-gnu/libpq.so.5.14
    6552:20220307:124440.007 7f48ff919000-7f48ff91a000 rw-p 00051000 fe:01 1184179 /usr/lib/x86_64-linux-gnu/libpq.so.5.14
    6552:20220307:124440.007 7f48ff91a000-7f48ff91c000 rw-p 00000000 00:00 0
    6552:20220307:124440.007 7f48ff920000-7f48ff924000 rw-s 00000000 00:01 14 /SYSV00000000 (deleted)
    6552:20220307:124440.007 7f48ff924000-7f48ff925000 r--p 00000000 fe:01 2753068 /lib/x86_64-linux-gnu/ld-2.31.so
    6552:20220307:124440.007 7f48ff925000-7f48ff945000 r-xp 00001000 fe:01 2753068 /lib/x86_64-linux-gnu/ld-2.31.so
    6552:20220307:124440.007 7f48ff945000-7f48ff94d000 r--p 00021000 fe:01 2753068 /lib/x86_64-linux-gnu/ld-2.31.so
    6552:20220307:124440.007 7f48ff94d000-7f48ff94e000 rw-s 00000000 00:01 9 /SYSV00000000 (deleted)
    6552:20220307:124440.007 7f48ff94e000-7f48ff94f000 r--p 00029000 fe:01 2753068 /lib/x86_64-linux-gnu/ld-2.31.so
    6552:20220307:124440.007 7f48ff94f000-7f48ff950000 rw-p 0002a000 fe:01 2753068 /lib/x86_64-linux-gnu/ld-2.31.so
    6552:20220307:124440.007 7f48ff950000-7f48ff951000 rw-p 00000000 00:00 0
    6552:20220307:124440.007 7fff64b23000-7fff64b44000 rw-p 00000000 00:00 0 [stack]
    6552:20220307:124440.007 7fff64bfa000-7fff64bfe000 r--p 00000000 00:00 0 [vvar]
    6552:20220307:124440.007 7fff64bfe000-7fff64c00000 r-xp 00000000 00:00 0 [vdso]
    6552:20220307:124440.007 ================================
    6552:20220307:124440.007 Please consider attaching a disassembly listing to your bug report.
    6552:20220307:124440.007 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    6533:20220307:124440.010 One child process died (PID:6552,exitcode/signal:1). Exiting ...
    6546:20220307:124440.010 HA manager has been paused
    6546:20220307:124440.021 HA manager has been stopped
    6533:20220307:124440.022 Zabbix Server stopped. Zabbix 6.0.1 (revision a80cb13868).
