zabbix agent not running on zabbix server
  • alexswamp
    • Oct 2021
    • 11
    Hi everyone!
    I need to move my Zabbix server to my other Hypervizor, and after the move i started my zabbix. First can't connect to db, but i fix it. The second problem is local zabbix agent. It not run and can't start it.
    On Zabbix Agent configure i try to add 'Server' his local ip (127.0.0.1) and also try his valid IPv4. it's also try in 'ServerActive'.
  • LenR
    • Sep 2009
    • 1011
    Check the logs
    • alexswamp
      • Oct 2021
      • 11
      Originally posted by LenR
      Check the logs
      /var/log/zabbix/zabbix_agentd.log
      60043:20220304:203810.479 Starting Zabbix Agent [Zabbix server]. Zabbix 6.0.1 (revision a80cb13868).
      60043:20220304:203810.479 **** Enabled features ****
      60043:20220304:203810.479 IPv6 support: YES
      60043:20220304:203810.479 TLS support: YES
      60043:20220304:203810.479 **************************
      60043:20220304:203810.480 using configuration file: /etc/zabbix/zabbix_agentd.conf
      60043:20220304:203810.480 agent #0 started [main process]
      60044:20220304:203810.481 agent #1 started [collector]
      60045:20220304:203810.481 agent #2 started[listener #1]
      60046:20220304:203810.482 agent #3 started[listener #2]
      60047:20220304:203810.482 agent #4 started[listener #3]
      60048:20220304:203810.484 agent #5 started [active checks #1]
      60048:20220304:203810.487 Unable to connect to [127.0.0.1]:10051 [cannot connect to [[127.0.0.1]:10051]: [111] Connection refused]
      60048:20220304:203810.487 Active check configuration update started to fail
      60048:20220304:204010.514 Active check configuration update from [127.0.0.1:10051] is working again
      When i try start zabbix-aggentd it's fall down:
      systemctl start zabbix-agent.service
      it@zabbix:~$ journalctl -xe
      -- Defined-By: systemd
      -- Support: http://www.ubuntu.com/support
      -- A start job for unit zabbix-agent.service has begun execution.
      -- The job identifier is 4034530.
      Mar 16 15:15:48 zabbix zabbix_agentd[651026]: zabbix_agentd [651026]: ERROR: parameter "TLSConnect" value requires "TL>
      Mar 16 15:15:48 zabbix systemd[1]: zabbix-agent.service: Control process exited, code=exited, status=1/FAILURE
      -- Subject: Unit process exited
      -- An ExecStart= process belonging to unit zabbix-agent.service has exited.
      -- The process' exit code is 'exited' and its exit status is 1.
      Mar 16 15:15:48 zabbix systemd[1]: zabbix-agent.service: Failed with result 'exit-code'.
      -- Subject: Unit failed
      -- The unit zabbix-agent.service has entered the 'failed' state with result 'exit-code'.
      Mar 16 15:15:48 zabbix systemd[1]: Failed to start Zabbix Agent.
      -- Subject: A start job for unit zabbix-agent.service has failed
      -- A start job for unit zabbix-agent.service has finished with a failure.
      -- The job identifier is 4034530 and the job result is failed.
      Mar 16 15:15:48 zabbix sudo[651023]: pam_unix(sudo:session): session closed for user root
      • LenR
        • Sep 2009
        • 1011
        Isn't that log from 3/4/22 and your startup error is from today? I don't think that's your current log, which appears to have worked OK on that day with verison 6.0.1.
        This line is suspicious: ERROR: parameter "TLSConnect" value requires "TL>
        Have you tried to make changes with TLS?
        • alexswamp
          • Oct 2021
          • 11
          I don't have freshed log file (.log is empty, .log.1 is on the top).
          I don't change anything on config file, it's works fine, i just move the zabbix vm to other hypervizor.
          • LenR
            • Sep 2009
            • 1011
            Post your zabbix agent config file.
            • alexswamp
              • Oct 2021
              • 11
              it@zabbix:~$ sudo cat /etc/zabbix/zabbix_agentd.d/
              cat: /etc/zabbix/zabbix_agentd.d/: Is a directory
              it@zabbix:~$ sudo cat /etc/zabbix/zabbix_agentd.conf
              # This is a configuration file for Zabbix agent daemon (Unix)
              # To get more information about Zabbix, visit http://www.zabbix.com
              ### Option: PidFile
              # Name of PID file.
              # Mandatory: no
              # Default:
              # PidFile=/tmp/zabbix_agentd.pid
              PidFile=/run/zabbix/zabbix_agentd.pid
              ### Option: LogType
              # Specifies where log messages are written to:
              # system - syslog
              # file - file specified with LogFile parameter
              # console - standard output
              # Mandatory: no
              # Default:
              # LogType=file
              ### Option: LogFile
              # Log file name for LogType 'file' parameter.
              # Mandatory: yes, if LogType is set to file, otherwise no
              # Default:
              # LogFile=
              LogFile=/var/log/zabbix/zabbix_agentd.log
              ### Option: LogFileSize
              # Maximum size of log file in MB.
              # 0 - disable automatic log rotation.
              # Mandatory: no
              # Range: 0-1024
              # Default:
              # LogFileSize=1
              LogFileSize=1
              ### Option: DebugLevel
              # Specifies debug level:
              # 0 - basic information about starting and stopping of Zabbix processes
              # 1 - critical information
              # 2 - error information
              # 3 - warnings
              # 4 - for debugging (produces lots of information)
              # 5 - extended debugging (produces even more information)
              # Mandatory: no
              # Range: 0-5
              # Default:
              DebugLevel=3
              ### Option: SourceIP
              # Source IP address for outgoing connections.
              # Mandatory: no
              # Default:
              # SourceIP=
              ### Option: AllowKey
              # Allow execution of item keys matching pattern.
              # Multiple keys matching rules may be defined in combination with DenyKey.
              # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
              # Parameters are processed one by one according their appearance order.
              # If no AllowKey or DenyKey rules defined, all keys are allowed.
              # Mandatory: no
              ### Option: DenyKey
              # Deny execution of items keys matching pattern.
              # Multiple keys matching rules may be defined in combination with AllowKey.
              # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
              # Mandatory: no
              # Default:
              # DenyKey=system.run[*]
              ### Option: EnableRemoteCommands - Deprecated, use AllowKey=system.run[*] or DenyKey=system.run[*] instead
              # Internal alias for AllowKey/DenyKey parameters depending on value:
              # 0 - DenyKey=system.run[*]
              # 1 - AllowKey=system.run[*]
              # Mandatory: no
              ### Option: LogRemoteCommands
              # Enable logging of executed shell commands as warnings.
              # 0 - disabled
              # 1 - enabled
              # Mandatory: no
              # Default:
              # LogRemoteCommands=0
              ##### Passive checks related
              ### Option: Server
              # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
              # Incoming connections will be accepted only from the hosts listed here.
              # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
              # and '::/0' will allow any IPv4 or IPv6 address.
              # '0.0.0.0/0' can be used to allow any IPv4 address.
              # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
              # Mandatory: yes, if StartAgents is not explicitly set to 0
              # Default:
              # Server=
              Server=127.0.0.1
              ### Option: ListenPort
              # Agent will listen on this port for connections from the server.
              # Mandatory: no
              # Range: 1024-32767
              # Default:
              # ListenPort=10050
              ### Option: ListenIP
              # List of comma delimited IP addresses that the agent should listen on.
              # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
              # Mandatory: no
              # Default:
              # ListenIP=0.0.0.0
              ### Option: StartAgents
              # Number of pre-forked instances of zabbix_agentd that process passive checks.
              # If set to 0, disables passive checks and the agent will not listen on any TCP port.
              # Mandatory: no
              # Range: 0-100
              # Default:
              # StartAgents=3
              ##### Active checks related
              ### Option: ServerActive
              # List of comma delimited IP addresses or DNS names (address:port) pairs or clusters (address:port;address2:port) of Zabbix servers and Zabbix proxies for active checks.
              # If port is not specified, default port is used.
              # Cluster nodes need be separated by semicolon.
              # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
              # If port is not specified, square brackets for IPv6 addresses are optional.
              # If this parameter is not specified, active checks are disabled.
              # Example for multiple servers:
              # ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
              # Example for HA:
              # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051;zabbix.cluster.node3
              # Example for HA with two clusters and one server:
              # ServerActive=zabbix.cluster.node1;zabbix.cluster.n ode2:20051,zabbix.cluster2.node1;zabbix.cluster2.n ode2,zabbix.domain
              # Mandatory: no
              # Default:
              # ServerActive=
              ### Option: Hostname
              # List of comma delimited unique, case sensitive hostnames.
              # Required for active checks and must match hostnames as configured on the server.
              # Value is acquired from HostnameItem if undefined.
              # Mandatory: no
              # Default:
              # Hostname=
              Hostname=Zabbix server
              ### Option: HostnameItem
              # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
              # Does not support UserParameters or aliases.
              # Mandatory: no
              # Default:
              # HostnameItem=system.hostname
              ### Option: HostMetadata
              # Optional parameter that defines host metadata.
              # Host metadata is used at host auto-registration process.
              # An agent will issue an error and not start if the value is over limit of 255 characters.
              # If not defined, value will be acquired from HostMetadataItem.
              # Mandatory: no
              # Range: 0-255 characters
              # Default:
              # HostMetadata=
              ### Option: HostMetadataItem
              # Optional parameter that defines an item used for getting host metadata.
              # During an auto-registration request an agent will log a warning message if
              # the value returned by specified item is over limit of 255 characters.
              # This option is only used when HostMetadata is not defined.
              # Mandatory: no
              # Default:
              # HostMetadataItem=
              ### Option: HostInterface
              # Optional parameter that defines host interface.
              # Host interface is used at host auto-registration process.
              # If not defined, value will be acquired from HostInterfaceItem.
              # Mandatory: no
              # Default:
              # HostInterface=
              ### Option: HostInterfaceItem
              # Optional parameter that defines an item used for getting host interface.
              # This option is only used when HostInterface is not defined.
              # Mandatory: no
              # Default:
              # HostInterfaceItem=
              ### Option: RefreshActiveChecks
              # How often list of active checks is refreshed, in seconds.
              # Mandatory: no
              # Range: 60-3600
              # Default:
              # RefreshActiveChecks=120
              ### Option: BufferSend
              # Do not keep data longer than N seconds in buffer.
              # Mandatory: no
              # Range: 1-3600
              # Default:
              # BufferSend=5
              ### Option: BufferSize
              # Maximum number of values in a memory buffer. The agent will send
              # all collected data to Zabbix Server or Proxy if the buffer is full.
              # Mandatory: no
              # Range: 2-65535
              # Default:
              # BufferSize=100
              ### Option: MaxLinesPerSecond
              # Maximum number of new lines the agent will send per second to Zabbix Server
              # or Proxy processing 'log' and 'logrt' active checks.
              # The provided value will be overridden by the parameter 'maxlines',
              # provided in 'log' or 'logrt' item keys.
              # Mandatory: no
              # Range: 1-1000
              # Default:
              # MaxLinesPerSecond=20
              ############ ADVANCED PARAMETERS #################
              ### Option: Alias
              # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
              # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
              # Different Alias keys may reference the same item key.
              # For example, to retrieve the ID of user 'zabbix':
              # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.:([0-9]+),,,,\1]
              # Now shorthand key zabbix.userid may be used to retrieve data.
              # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
              # Mandatory: no
              # Range:
              # Default:
              ### Option: Timeout
              # Spend no more than Timeout seconds on processing
              # Mandatory: no
              # Range: 1-30
              # Default:
              # Timeout=3
              ### Option: AllowRoot
              # Allow the agent to run as 'root'. If disabled and the agent is started by 'root', the agent
              # will try to switch to the user specified by the User configuration option instead.
              # Has no effect if started under a regular user.
              # 0 - do not allow
              # 1 - allow
              # Mandatory: no
              # Default:
              # AllowRoot=0
              ### Option: User
              # Drop privileges to a specific, existing user on the system.
              # Only has effect if run as 'root' and AllowRoot is disabled.
              # Mandatory: no
              # Default:
              # User=zabbix
              # NOTE: This option is overriden by settings in systemd service file!
              ### Option: Include
              # You may include individual files or all files in a directory in the configuration file.
              # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
              # Mandatory: no
              # Default:
              # Include=
              Include=/etc/zabbix/zabbix_agentd.d/*.conf
              # Include=/usr/local/etc/zabbix_agentd.userparams.conf
              # Include=/usr/local/etc/zabbix_agentd.conf.d/
              # Include=/usr/local/etc/zabbix_agentd.conf.d/*.conf
              ### Option: UnsafeUserParameters
              # Allow all characters to be passed in arguments to user-defined parameters.
              # The following characters are not allowed:
              # Additionally, newline characters are not allowed.
              # 0 - do not allow
              # 1 - allow
              # Mandatory: no
              # Range: 0-1
              # Default:
              # UnsafeUserParameters=0
              ### Option: UserParameter
              # User-defined parameter to monitor. There can be several user-defined parameters.
              # Format: UserParameter=<key>,<shell command>
              # See 'zabbix_agentd' directory for examples.
              # Mandatory: no
              # Default:
              # UserParameter=
              ### Option: UserParameterDir
              # Directory to execute UserParameter commands from. Only one entry is allowed.
              # When executing UserParameter commands the agent will change the working directory to the one
              # specified in the UserParameterDir option.
              # This way UserParameter commands can be specified using the relative ./ prefix.
              # Mandatory: no
              # Default:
              # UserParameterDir=
              ####### LOADABLE MODULES #######
              ### Option: LoadModulePath
              # Full path to location of agent modules.
              # Default depends on compilation options.
              # To see the default path run command "zabbix_agentd --help".
              # Mandatory: no
              # Default:
              # LoadModulePath=${libdir}/modules
              # Module to load at agent startup. Modules are used to extend functionality of the agent.
              # Formats:
              # LoadModule=<module.so>
              # LoadModule=<path/module.so>
              # LoadModule=</abs_path/module.so>
              # Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
              # If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
              # It is allowed to include multiple LoadModule parameters.
              # Mandatory: no
              # Default:
              # LoadModule=
              ####### TLS-RELATED PARAMETERS #######
              ### Option: TLSConnect
              # How the agent should connect to server or proxy. Used for active checks.
              # Only one value can be specified:
              # unencrypted - connect without encryption
              # psk - connect using TLS and a pre-shared key
              # cert - connect using TLS and a certificate
              # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
              # Default:
              TLSConnect=psk
              ### Option: TLSAccept
              # What incoming connections to accept.
              # Multiple values can be specified, separated by comma:
              # unencrypted - accept connections without encryption
              # psk - accept connections secured with TLS and a pre-shared key
              # cert - accept connections secured with TLS and a certificate
              # Default:
              TLSAccept=psk
              ### Option: TLSCAFile
              # Full pathname of a file containing the top-level CA(s) certificates for
              # peer certificate verification.
              # Mandatory: no
              # Default:
              # TLSCAFile=
              ### Option: TLSCRLFile
              # Full pathname of a file containing revoked certificates.
              # Mandatory: no
              # Default:
              # TLSCRLFile=
              ### Option: TLSServerCertIssuer
              # Allowed server certificate issuer.
              # Mandatory: no
              # Default:
              # TLSServerCertIssuer=
              ### Option: TLSServerCertSubject
              # Allowed server certificate subject.
              # Mandatory: no
              # Default:
              # TLSServerCertSubject=
              ### Option: TLSCertFile
              # Full pathname of a file containing the agent certificate or certificate chain.
              # Mandatory: no
              # Default:
              # TLSCertFile=
              ### Option: TLSKeyFile
              # Full pathname of a file containing the agent private key.
              # Mandatory: no
              # Default:
              # TLSKeyFile=
              ### Option: TLSPSKIdentity
              # Unique, case sensitive string used to identify the pre-shared key.
              # Mandatory: no
              # Default:
              # TLSPSKIdentity=
              ### Option: TLSPSKFile
              # Full pathname of a file containing the pre-shared key.
              # Mandatory: no
              # Default:
              # TLSPSKFile=
              ####### For advanced users - TLS ciphersuite selection criteria #######
              ### Option: TLSCipherCert13
              # Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
              # Override the default ciphersuite selection criteria for certificate-based encryption.
              # Mandatory: no
              # Default:
              # TLSCipherCert13=
              # GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
              # Example for GnuTLS:
              # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
              # Example for OpenSSL:
              # EECDH+aRSA+AES128:RSA+aRSA+AES128
              # Mandatory: no
              # Default:
              # TLSCipherCert=
              ### Option: TLSCipherPSK13
              # Override the default ciphersuite selection criteria for PSK-based encryption.
              # Example:
              # TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
              # Mandatory: no
              # Default:
              # TLSCipherPSK13=
              # NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
              # kECDHEPSK+AES128:kPSK+AES128
              # Mandatory: no
              # Default:
              # TLSCipherPSK=
              ### Option: TLSCipherAll13
              # Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
              # Example:
              # TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
              # Mandatory: no
              # Default:
              # TLSCipherAll13=
              # NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
              # EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
              # Mandatory: no
              # Default:
              # TLSCipherAll=
              ####### For advanced users - TCP-related fine-tuning parameters #######
              ## Option: ListenBacklog
              # The maximum number of pending connections in the queue. This parameter is passed to
              # listen() function as argument 'backlog' (see "man listen").
              # Mandatory: no
              # Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
              # Default: SOMAXCONN (hard-coded constant, depends on system)
              # ListenBacklog=
              it@zabbix:~$
              • ITOMDave
                • Nov 2018
                • 53
                Looks to me like PSK encryption has been partly enabled.
                Your zabbix_agentd.conf file hase the following entries "TLSConnect=psk" and "TSLAccept=psk" but the other entries related to PSK encryption aren't completed, e.g. TLSPSKIdentity and TLSPSKFile
                Perhaps take a look at https://www.zabbix.com/documentation...re_shared_keys for more information.
                • erlerzop
                  • Apr 2022
                  Log in to the Zabbix frontend and go to Configuration > Hosts > Create Host. Enter the hostname for the device you are adding. This must match the hostname you configured in the agent.
                  • erlerzop
                    • Apr 2022
                    techzpod mobdro download
